20 Most Recent Sony PFM-42X1N 42 in. HD-Ready Plasma Television Questions & Answers
this Sony is a MONITOR not a TV. You need a cable box or a satellite tuner/receiver. There is no built in TV Tuner in this model
Sony PFM-42X1N... | Answered on Apr 02, 2014
Model indicated is a plasma (let me know if different model) and likely a bad board like power supply or such.
Also if set a few years old:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Sony PFM-42X1N... | Answered on Mar 27, 2012
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one. After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Sony PFM-42X1N... | Answered on May 04, 2008
Flat panel TV's typically do not have "bulbs," but rather backlighting.  Plasma displays are especially touchy during movement.  I would suggest checking your warranty status, as it's probably not something you can easily repair.  If you wanted to take on the repair yourself, be careful not to lay down the screen, as it will drastically shorten the life of the Plasma display.  I would start with checking the system boards for possible damage, since you did hear a "click," It was probably a fuse, chip, etc.
Sony PFM-42X1N... | Answered on Oct 19, 2007
and if it works otherwise why worry about a click when powering off . as we say if not broke do not fix
Sony Televison &... | Answered 2 days ago
ASK GOOGLE FOR CODE LIST
Sony Televison &... | Answered on Jan 22, 2020
If it came with batteries replace them with new Duracell batteries. The batteries are probably Chinese, low quality and partially drained.
It is never good to use Universal remotes. These days people buy Facsimile remotes which are a clone of the original will all the same buttons and features as the original.
Google
Sony Bravia (model number) replacement remote
Sony Televison &... | Answered on Jan 15, 2020
Sony PFM-42X1N 42 in. HD-Ready Plasma Television Logo
Popular Tags
14 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
watching cable tv
  • Televison & Video
