20 Most Recent Sony FD Trinitron WEGA KV-36FS120 36" TV Questions & Answers
In accordance with facility to watch The Wire online,you can go through entertaining .Watch Online The Wire Season 4 Episode6 - Watch-Series watch online series The Wire season 4 episode 6,download full episodes for freeWatch The Wire Online - Full Episodes ofThe Wire & More TV Set in Baltimore, this show centers around thecity's inner-city drug scene. It starts as ... the Wire - Watch Full Episodes of TV Shows Onlinecility to watch The Wire online with blinkx Remote
Sony FD... | Answered on Mar 25, 2019
Probably defective power supply. Fixya is unable to recommend replacement parts sources.
Sony FD... | Answered on Jan 25, 2018
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony FD... | Answered on May 27, 2016
http://electro-medical.blogspot.com/
Sony FD... | Answered on May 21, 2016
try to adjust in remote control the fine tuning or if there is a system in audio you can try it also.
Sony FD... | Answered on Jan 10, 2016
Check and replace damaged component/s at its horizontal scan output section circuit.Check the LOT (Line Output Transformer) too for damage.Replace the horizontal scan output transistor.Check the input voltage to LOT.If the voltage is absent check the feeder resistor; if any.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
Sony FD... | Answered on Sep 18, 2015
When you unplugged it you removed power and the memory setting for full screen was wiped out. Go into your menu for screen size controls, reset, and all should be fine.
Sony FD... | Answered on Sep 07, 2015
I think you might be referring to what's called, 'picture in picture (PIP). Its a feature of the TV that allows one to see what is on other channels while your current channel stays on the screen. Refer to your manual of how to disable, or if no manual, play with the remote to see what button eliminates it.
Sony FD... | Answered on Feb 18, 2015
the 9 blink code is caused by a bad diode on the pc board. The zero crossing detect circuit is not allowing the power supply to come on .
Sony FD... | Answered on Feb 04, 2015
The power seems ok as it was working fine this morning had kids channel on for my daughter for about 1-2 hours while I was pottering about cleaning then daughter told me TV had gone black
Sony FD... | Answered on Dec 07, 2014
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sony FD... | Answered on Dec 04, 2014
Sounds like 'Picture-in-Picture' is interfering.
You can try pulling the AC plug for an hour or two to 'reset' ii of check the user guide for operation:
Sony FD... | Answered on Oct 23, 2014
If u move the tv pictures come back on clear and good,no bruses to the pictures at all?Yes,this tv can be fix the PCB main board is cracks or borkens,could be mend to it by steal rods and solder joints by a tv tech. to fix it.But if the pictures have bruses in it.The tv picture tube is damage,sorry this tv garbage,not worth fixing.
vertical circuit is out, some component failed. turn it on and when the line comes on hit the top of the case with the flat of your hand, if the line fluctuates or goes away you have a bad solder connection on the circuit board. if it doesn't make any difference when you smack it then something has failed completely. no user repairable parts inside.
Sony FD... | Answered on Sep 26, 2014
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
523 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony tv model kv36fs320 no picture
  • Televison & Video
