20 Most Recent
Sony FD Trinitron KD-36XS955 36" TV Questions & Answers
Sony KD-36XS955 Will
Please replace 2 ICs on DZ board of tv to solve the issue as discussed in chat session.
Thanks.
7/11/2011 1:41:22 AM •
Sony FD...
Answered
on Jul 11, 2011
Standby time light on and
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
6/8/2011 3:51:19 AM •
Sony FD...
Answered
on Jun 08, 2011
Audio and picture go dead red light blinks 7 times
A protection circuit has cut in - possibly due to a fault in the line output stage (flyback transformer could be short-circuit and horizontal output transistor could also be shorted).
Assuming the power supply/HT rail is all OK, replace the above parts, touch up any suspect solder joints, check and replace any capacitors (electrolytic and the tuning caps in the collector of the horizontal transistor - always replace these caps (rated at around 2kV - 6kV) whenever you replace the flyback)
2/18/2011 4:11:42 PM •
Sony FD...
Answered
on Feb 18, 2011
Sony KD-36XS955 36 inch wega
It is one of two issues, the blue video driver is defective, or the blue gun in the picture tube is open. This will need a tv tech to varify the problem and suggest a course of action.
2/18/2011 4:03:23 PM •
Sony FD...
Answered
on Feb 18, 2011
My screen has lost any red toning and is just
On your component cable (GREEN/BLUE/RED) check the connector for the RED on on both the TV and the device it is connected to. Also check the the RED for the VIDEO and the RED for the AUDIO are not switched on both the TV and the device as well.
Good Luck...
2/24/2010 10:30:42 PM •
Sony FD...
Answered
on Feb 24, 2010
No Picture, No sound, No OSD, Stby light flashes 20 times
well intermittinly shutting down only thing i can say is go thru that board may be getting good reading on transistor pull them out recheck
sounds like a bad cap make sure nothing is soldered together start from the beginning good luck shad tv man
5/3/2009 10:53:59 PM •
Sony FD...
Answered
on May 03, 2009
