20 Most Recent Sony FD Trinitron WEGA KV-34XBR910 34" TV Questions & Answers
4answers
Sony kv-34xbr910 wont turn on
I have sony 34 XBR Tube trinitron HD TV. We are not using the TV because it keep giving us 6 blinks and does not turn on
10/18/2021 11:47:48 PM • Sony FD... • Answered on Oct 18, 2021
0answers
Hello we have a sony kv34xbr910 tv that we cannot
Here is a link to the owners manual online. Specifically look at page 100 of the manual for a master password. Good Luck : )
http://www.docs.sony.com/release/KV34XBR910.pdf
7/26/2011 9:10:20 PM • Sony FD... • Answered on Jul 26, 2011
The source indicator stays on
Please press Info/ Display button on TV Remote so on-screen display that shows source will disappear.
Please note that only Sony TV Remote will work to close/ disappear on-screen display. Universal remote may not have that "Info or Display" button for that.
Hope this will help.
Thanks.
5/10/2011 11:49:13 PM • Sony FD... • Answered on May 10, 2011
The TV will not turn on. It blinks in standby for
6 blinks = No Horizontal (H STOP), no raster, goes to the blinking self diagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206 (or similar component references for your model) and replace flyback transformer if required.
Generally, whenever horizontal OCP (over current protection) occurs, the primary cause is usually the flyback transformer (these short circuit/burn out), the horizontal output transistor(s) and the tuning capacitors in the transistor(s) collector circuit must all be replaced together. It is also a good idea to check the ABL (or beam limiter) circuit as components may have been compromised in it due to the failing flyback.
You could take it to a service centre and obtain a quote for estimated repair costs, then you can decide afterwards if it is worth repairing or not. It may not be economical and/or expensive.
3/3/2011 12:24:46 PM • Sony FD... • Answered on Mar 03, 2011
TV won't stay on. Standby light flashes 5-10
Hello
Blinking of standby light in Sony sets are fault indication. You just count the exact number of blinks occur at on instance, say, after you switch On and OFF by its front panel power switch, not by remote control hanset. Just count it atleast 4 times, count it keenly and inform it to me, and let me reach to the nearest falult point; or sometimes to the exact point. OK.
12/6/2010 7:54:55 AM • Sony FD... • Answered on Dec 06, 2010
Tv try to turn on as soonest i am pluging it to
Yes, its normal as TV remember its last status like channel number/ AV input, volume level, video settings etc in its memory. If you put TV in standby and then unplug it, TV will turn on in standby mode after replugging back in.
Thanks.
9/22/2009 11:11:24 PM • Sony FD... • Answered on Sep 22, 2009
2answers
Set makes poping sound, but does not turn on, red standy light flashes
problem doesn't seem to be on the power supply board only! had the service center check the high voltage section already? does the popping sound like the one popcorns make?
11/26/2007 5:00:55 AM • Sony FD... • Answered on Nov 26, 2007
Tv doesn't respond to commands
Check the battery if its still good. if not replace with new one. if its still good, open the remote and inspect for loose connection. resolder if necessary. check also for possible crack pcb. good luck!
2/22/2007 9:46:28 AM • Sony FD... • Answered on Feb 22, 2007
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 2 days ago
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered on Apr 21, 2024
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Circuit diagram of sony kv-sz25m80
str no
2/26/2024 4:44:54 PM • Sony Televison &... • Answered on Feb 26, 2024
I have a Sony Bravia model no klv-22bx350 powers on them shuts down blinks 2times
2 red light blinks can mean a power supply problem that can be caused by a problem on the main board. An authorised Sony repair shop can fix that for you.
2/20/2024 8:03:27 AM • Sony Televison &... • Answered on Feb 20, 2024
Sony FD Trinitron WEGA KV-34XBR910 34" TV Logo
15 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kv 34xbr910 wont turn
  • Televison & Video
