20 Most Recent
Sony FD Trinitron WEGA KV-36HS500 36" TV Questions & Answers
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
10/8/2022 5:53:55 AM •
Sony FD...
Answered
on Oct 08, 2022
Sony trinitron kv32fs100 won't turn on 5 red lights blinking
We've heard this before from appliance repair persons, auto repair persons, etc. "Go out and buy a new TV, this one will be too expensive to fix." And then it turns out to be a $5 part. If this fixes it, you just saved yourself $800 or so.
11/18/2014 2:01:57 PM •
Sony FD...
Answered
on Nov 18, 2014
Problems sony wega tv
Do the standby light ON. If not check the 5V supply rail on the main board. If standby light is ON, and it blinks? If so, these blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
7/27/2014 3:41:28 AM •
Sony FD...
Answered
on Jul 27, 2014
Why ami experiencing a distortion noise while using av sony 21 inch ctv ha21m80
If there is distortion and noise, while using the TV, for on-air transmission, and there is no distortion or noise while using it AV, be sure that it tuner is faulty. Check the Ariel connection first, for discontinuity or loose contacts. If it found OK, replace the tuner. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" or "
Magazine" will make surf easy. Pull up older posts. Surf the site with patience.
Do a search by type in the brand name of your device at its search box and press "Enter".
7/6/2014 3:23:46 AM •
Sony FD...
Answered
on Jul 06, 2014
I have a 36" TV that won't work - Red LED light blinks 5 times
The 5 blinks indicates a White Balance Failure. This involves checking voltages and components tied directly to the CRT. I would not suggest any attempt for self repair. The cost for this repair should not be significant. Figure a parts cost in the $30-$50 range at worst.
Dan
1/11/2013 6:25:22 PM •
Sony FD...
Answered
on Jan 11, 2013
Sony bravia KDL-V40XBR1 7 blinks
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help. It is powered by Google.You might get the details of availablilty of spare parts too, by the the ads there.
5/25/2012 1:44:17 PM •
Sony FD...
Answered
on May 25, 2012
My sony wega trinitron 21
Hello
The fault with your TV is with some loose contact inside it. Normally most Trinitron TVs shows this problem due to loose contact in the video output card. Video output card is pluged diretly to the picture tube base, and can be detachable. You can pull it out very carefully without damaging the pins of of the picture tube. Most of the components in this board will heat up during working. Repeated heating and cooling will make the solder joints of the most heated components to get loose contacted. Normally, these loose contacts are very difficult to detect because they will be microscopic. Just do as what we do for this type of fault.
Resolder most of the suspected solder terminals, with applying a little more solder, without making any solder bridge in between the solder terminals. This will solve the problem of your TV. OK.
6/23/2011 5:28:30 PM •
Sony FD...
Answered
on Jun 23, 2011
Is the model KDF E42A10
As it has a tube, there seems no actual reason for that. The glass cannot change optical characteristics nor the coating on the inside of the tube. Maybe it is an optical illusion.
3/28/2011 4:14:49 PM •
Sony FD...
Answered
on Mar 28, 2011
I have recently switched to
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Since we know you are using a coax cable to connect the receiver toTV1, check the receiver's back panel for the output name. If your receiver hasa "TV CH 3/4 out":Tune TV to channel 3 or channel 4, if it is labeled "Home Distribution": TuneTV to channel 62 or 75. We also want to ensure that the TV and thereceiver are connected properly, please visit this link to for moreinformation: http://www.dishnetwork.com/SupportSection/setup-receiver-totv.Once we have made sure everything is connected properly, unplug receiver for 10seconds then plug it back in, this will reset the receiver. If we are still notgetting a picture connect another component (VCR, DVD Player, etc.) to the sameTV, using same cable, same input, and same channel to see if it works. If youget a picture with the other component give us a call at 1-800-333-DISH (3474)for some additional troubleshooting. If it doesn't work with the othercomponent then replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
3/18/2011 2:28:11 PM •
Sony FD...
Answered
on Mar 18, 2011
Isn't turning on, goes on
That means the EHT has exceeded 33KV and it will shut down.
Probably caused by a faulty/maladjusted power supply. Check the 135Volt rail.
Hope that helps.
3/1/2011 3:20:18 PM •
Sony FD...
Answered
on Mar 01, 2011
