20 Most Recent
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Questions & Answers
My sony kv-40xbr800 blinks 6
The problem is on the 'A' circuit board. It is the IC504.Or, it is a low voltage drop or a short. Replace the "A" board. It is the front board on your right when you are at the rear of the set when you remove the cover. Look it up on the net. PS Don't touch the chassis while it is on...HIGH VOLTAGE !!!
5/17/2014 10:49:33 PM •
Sony FD...
Answered
on May 17, 2014
Sony FD Trinitron WEGA XBRKV-40XBR800 40 inch sony trinitron problem code 7
Six
blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206. Might be of faulty IC. Visit the site named 'Electro-help' for
more details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to see the latest updates. It will make search
easy. There are more than 1350 posts to different brand TVs now. Pull up older
posts there.
11/30/2012 9:30:58 AM •
Sony FD...
Answered
on Nov 30, 2012
posts there.
11/30/2012 9:30:50 AM •
Sony FD...
Answered
on Nov 30, 2012
Picture is flickering
What do you mean by this flickering. Provide more details please. Visit the site named '
Electro-help' for more
details. Click this
link. View it in
Timeslide" or
click the [
Home] tab to the latest updates. It will make search easy.
There are more than 1300 posts to different brand TVs now. Pull up older posts
there.
11/27/2012 3:45:26 PM •
Sony FD...
Answered
on Nov 27, 2012
Sony kv-40xbr800 blinks two times
- Two
blinks - B+ over current protection (OCP), unit goes to the standby mode
then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
6/9/2012 4:42:40 PM •
Sony FD...
Answered
on Jun 09, 2012
The picture gets brighter than usual then blacks
Either the processor of the tv is no longer capable of controlling the gain of the video final section or the transistors from it overheat. The screen blacks out because when the luminance goes up the current thru the tube goes out and when it reaches a level that is dangerous the X-Ray protection kicks in and cuts the high tension to the tube. When that happens the current thru it goes to 0 , the processor's video section is reseted and the transistor cool down so the process starts again.
All you can do is to open it and check the connections to the video final board (the one that is plugged to the tube) and the status of the transistor's radiators - they might need cleaning, use a soft plastic brush.
6/20/2011 3:37:53 PM •
Sony FD...
Answered
on Jun 20, 2011
Sony 40xbr800 wont turn on,
Six blinks points to No Horizontal or raster. The uProcessor detects a problem and enters the self test function shutting down the main power supply.
2/17/2011 9:14:15 AM •
Sony FD...
Answered
on Feb 17, 2011
My tv is a sony xbr. somehow we got ourselves a
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
2/17/2011 5:08:56 AM •
Sony FD...
Answered
on Feb 17, 2011
Tv won't go on-stand by light blinks on and off
How many times does it blink in between each pause? This is a self-test diagnostic code that will help us locate the source of the problem. So please count carefully and let me know.
Sai.
1/23/2011 5:04:06 PM •
Sony FD...
Answered
on Jan 23, 2011
KV 40XBR800 will not turn on
Likely to have two ic's bad....both are the same. Part number MCZ3001D. Located close to each other. Must be unsoldered and new put in. I have fixed several with this problem
10/28/2010 12:36:15 AM •
Sony FD...
Answered
on Oct 28, 2010
My computer can not turned on.
First 11 blinks
Hello
It is a fault indiation. We will call it as self-diagnosis. That is the microcomputer inside your tv detects two serious faults inside the circuits, and shuts off the rest of the circuit from going on, to prevent further damage. The first 11 blinks indicates that there are some bad solder connections on "D" board or the transistors it it may be gone out. The following 5 blinks shows that there is some fault IN the AKB circuits [Automatic Kin bias], the timer or standby indicator blinks for about 30 seconds and goes to the self diagnosis function again. There must be something wrong with the video section. Just check video output section of "C" board for fault.
I thinks that without thorough knowledge about the circuit and its components, you yoursef cannot rectify the problem. There is some series mistakes inside. It will be best for you to get it repaired from the authorised sevice center. Ok
10/22/2010 4:04:14 PM •
Sony FD...
Answered
on Oct 22, 2010
SOny FD TRINITRON WEGA XBRKV-40XBR800....IT STARTS
Hello
Your tv has problems in power regulator side, which is in the printed circuit board of the telivision. Sometimes it may due to some socket contact problems. You just contact a technician., while you cannot do it right by yourself.
10/16/2010 5:56:36 AM •
Sony FD...
Answered
on Oct 16, 2010
I have kv32hs420 with
hi
the problem is a horizontal deflection source
it could be a shorted horizontal out put transistor
also causing the transistor to overheat and go short is the flyback transformer
9/28/2010 2:12:45 AM •
Sony FD...
Answered
on Sep 28, 2010
Try to turn on but
The tv has entered protect mode due to a surge. Unplug the set for about half an hour and turn it back on. See if it does the trick. If it does not then it has probably knocked out some voltage regulator ICs that is causing the line to overload. In that case a component level fix should do the trick.
8/21/2010 7:06:11 AM •
Sony FD...
Answered
on Aug 21, 2010
