20 Most Recent
Sony FD Trinitron WEGA KV-32FV300 32" TV Questions & Answers
Flickering
When you say flickers?? does the sound stay on or does the whole set go on then off or is it just the picture that flickers on and off and sound does flicker too? need more info please.
2/20/2012 8:11:44 PM •
Sony FD...
Answered
on Feb 20, 2012
Sony FD Trinitron Wega KV-FV300.
Symptom shows that main circuit board of tv got some loose connection/ loose connector some where that is causing problem and slap/ hit on tv cabinet connect that connection temporarily for some time.
If you are handy with electronics stuff repair and can do solder work then check/ inspect solder joints on circuit board and resolder any dry/ cold solder joints/ connections that look dull or not shiny as compare to nearby solder joints.
If you are not familiar dong so then local tv repair shop will do this job for you.
Hope these info will help, let me know if there is additional question.
Thanks.
6/26/2011 10:27:58 PM •
Sony FD...
Answered
on Jun 26, 2011
Comes on and later goes blank
How much later? The Sony sets have a setting in the menu that turnes the TV off if there isnt' any input, Sometimes this feature gets messed up, and the feature has to be turned off, Check that out and see if that takes care of the problem.
8/28/2010 6:29:04 AM •
Sony FD...
Answered
on Aug 28, 2010
My TV is stuck on
Hi and welcome to FixYa,
Using the Sony's original remote, go to MENU, Channel settings and change "Channel Fix" to Off.
Good luck and thank you for asking FixYa.
1/13/2010 4:23:40 PM •
Sony FD...
Answered
on Jan 13, 2010
I have replaced the horizontal output transistor
I would first be suspicious of the flyback transformer if the HOT was shorted. I have also found many Sonys with shorted video output i.c. s which are on the CRT pc board. I do not recall if this model uses one output i.c. or three separate ones. Either way you can unplug the cabling feeding the crt board and try powering the set again. If the high voltage comes up you likely have a shorted video i.c. (The i.c. s short most likely because the crt momentarily arcs.) If this test does not result in a clearing of the over current problem I would, as I said initially, suspect the flyback. There are other possible causes, but those are the two I have seen most often.
11/10/2009 10:12:50 PM •
Sony FD...
Answered
on Nov 10, 2009
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
4/19/2009 6:25:54 PM •
Sony FD...
Answered
on Apr 19, 2009
Sony 19"
How many times does the green light flash? This green light can tell you the area where the problem is but it will not tell you what is bad.
8/16/2007 4:58:10 PM •
Sony FD...
Answered
on Aug 16, 2007
1/3rd of Bottom portion of Screen is blacked out
sound like you have cloced caption text on, this is not the same as the normal cloced caption, look on your rempte for caption or "cc". if you don't see it you will find it in your menu & turn it off.
have a good day.
1/2/2007 1:34:47 PM •
Sony FD...
Answered
on Jan 02, 2007
