20 Most Recent Sony KV-XR29M50 TV Questions & Answers
Power supply
To buy a new power supply, contact the authorized service center for Sony. If you wish to get it troubleshoot, check the site linked here. If you're sound in electronics, you can follow. http://electronicshelponline.blogspot.com/ Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
9/16/2013 5:03:48 PM • Sony KV-XR29M50... • Answered on Sep 16, 2013
manual
Displayed pictures blurred, no effect
power supply not work
9/16/2013 4:31:21 AM • Sony KV-XR29M50... • Answered on Sep 16, 2013
I am have data shet all mainboard RGB crt
If you wish to get some details about the schematic to Sony TVs, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts or type in the brand name and model number to of your set, to its search box, and press 'Enter'.
8/22/2013 5:52:34 AM • Sony KV-XR29M50... • Answered on Aug 22, 2013
KV-XR29M50 WITHIN FEW SECONDS +135V DROP
B+ of 135V is OK.here is a guide for you to have: Flyback Transformer If the Q511 is OK, then solder it back.Plugged the unit in , without the C Board connected to the CRT.If it powers On, completely, you just found the cause.If it has the same symptoms troubleshoot on the other Board.
10/21/2012 11:55:10 AM • Sony KV-XR29M50... • Answered on Oct 21, 2012
Hi,can i switch on the sonykv-xr29m50 without connections of yoke,crt,eht&picturetube coil (testing for +135v)
yes even with out the yoke and crt you can switch on the tv, you can check the primary supply 135v going to the horizontal section.
9/28/2012 11:13:48 AM • Sony KV-XR29M50... • Answered on Sep 28, 2012
0answers
Color is over red
The color of the Television is compose three color,the Red,Green and Blue.First thing to do is try to adjust the color adjustment.Adjust and balance the color.
8/18/2011 12:27:59 PM • Sony KV-XR29M50... • Answered on Aug 18, 2011
Comes on after 30 40minutes
Hello
Its picture tube base socket has damaged. Picture tube base socket is one diretly soldered to the base card, which in turn pluged onto the picture tube neck. Its focus control pin will usually get damaged, and this type of fault you describes here will occur. The time taken to clear up picture will vary according to atmosphereic humidty.
You can replace the base card. Unplug the base card from the picture tube base card [do it ver cauciously; not to shake it sideways or up-down - just pull it straight backwards; you may have to apply a little pressure to detach it from the picture tube neck]; resolder it out from the card and go for a new one. Replacing it will solve your TVs problem. OK.
5/6/2011 3:40:27 PM • Sony KV-XR29M50... • Answered on May 06, 2011
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered Yesterday
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered 3 days ago
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Circuit diagram of sony kv-sz25m80
str no
2/26/2024 4:44:54 PM • Sony Televison &... • Answered on Feb 26, 2024
Sony KV-XR29M50 TV Logo
13 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
power supply
  • Televison & Video
