20 Most Recent Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b Questions & Answers
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Symbol... | Answered on Mar 26, 2014
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Symbol... | Answered on Nov 02, 2013
What do you need to know / what do you already know ? This is a large question.
1. Are all your access points configured
2. For your captive portal you could use MikroTik software. There is a large community based on the software and step by step instructions to setup a captive portal.
Symbol... | Answered on Mar 01, 2011
the issue is if your using bridge mode then you have to use differnt IP for both Router
if your main router using this IP like 192.168.1.1
second router sute use folowing IP 192.168.2.1
it will work changing IP's
Symbol... | Answered on Apr 20, 2010
You can connect a console cable to the console port and login using a freeware terminal emulation app such as Tera Term Pro. The default password is: Symbol
PDF manual:
http://www.guardit.cn/UploadFiles/symbol_ap4131_engmanual.pdf
Use chapter 5 for instructions on creating a new authentication key that will match your computer setting.
Symbol... | Answered on Jul 01, 2009
Hello there, I believe you have a chat going as well? I will be glad to help you, please let me know if you want to do it this way or via chat... Do you have google chat or anything that we could maybe use? It will be pretty difficult to diagnose and fix in a back and forth email format.
Hello minhaj,
You can download the structure manual of Sympol Spectrum 24 4131 by Clicking Here
Thank you for using FixYa.
Symbol... | Answered on Apr 12, 2009
Hello Richard
It sounds as though your computer is set to the incorrect keyboard. I use a key board which I brought from the UK. The computer set me up with a US Keyboard settings. The @ symbol was hiding double quote " key. Short term I could press Shift+2 and get the @. What I did eventually was to go into Settings and change;
Settings - Devices - Typing - Advanced Keyboard Settings
So you have two choices
Change the keyboard settings
or
Go to the place on your keyboard where the symbol you see when you type is located on the keyboard. Pressing that will get you the @ symbol.
click COMMENT under my post if you need further help.
Symbol Computers... | Answered on Dec 09, 2019
IDEA IS GET THE BATTERY REPLACED AT A REPAIR SHOP
Symbol Computers... | Answered on Nov 24, 2019
most likely on the keyboard you get on the screen in the left bottom corner will be an alternative symbol option key
if not you might have to change the bbid on the wi fi router and all your other devices connected to it by removing the underscore
Symbol Computers... | Answered on Oct 05, 2019
Symbol Spectrum24 4131 Access Point (AP-4131-1050-Z2-WW) 802.11b Logo
18 questions posted
Popular Products
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symbol Computers & Internet
Most Popular Question
default ip address symbol spectrum24 ap
  • Computers & Internet
