20 Most Recent Sony KP-46V35 TV Questions & Answers
No power up when prompted on KP-46V35
Bad voltage regulator ic in power supply.
11/10/2011 9:42:33 PM • Sony KP-46V35 TV • Answered on Nov 10, 2011
Sonykp46v15 bottom half picture is black
Check your +26 and -26 voltages on your ic's.
11/10/2011 9:41:00 PM • Sony KP-46V35 TV • Answered on Nov 10, 2011
Green horizontal line in center of screen.
Bad vertical output ic. Also, check resistors and diodes around vertical output ic.
11/10/2011 9:37:42 PM • Sony KP-46V35 TV • Answered on Nov 10, 2011
SOUND BUT NO PICTURE WHEN DVD IS PLAYING
Need to check an av switching ic. Make sure you got the 12v going to the ic, if missing troublle shoot power supply. If it is there, bad ic. Or if it is low, unsolder vcc pin and check for right voltage to see if the ic is bringing down the voltage.
11/10/2011 9:35:44 PM • Sony KP-46V35 TV • Answered on Nov 10, 2011
Sony kp-46v15 convergence problem dont
Do not mess with those, they don't just go out. they are also for skew linearity, heighth, width for vertical and horizontal adjustments. If your convergence went out need to find convergence circuit and look on the plugs for your vcc voltages going to the convergence circuit. If missing, trace back to power supply and look for an open low value resistor.
11/10/2011 9:32:26 PM • Sony KP-46V35 TV • Answered on Nov 10, 2011
Blinking standby light and nothing else...
When Sony TVs detect a problem, they shutdown and present a blink code. The blinking should be a repeated count. Please report that count here as that indicates the circuit in which the problem was detected.
Thanks,
Dan
2/11/2009 4:23:27 AM • Sony KP-46V35 TV • Answered on Feb 11, 2009
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
9/10/2008 5:27:38 PM • Sony KP-46V35 TV • Answered on Sep 10, 2008
Slow video switching
I responded to the comment posted to the original problem/question. If you don't mind, I'd rather keep the discussion there for context.
Thanks,
Dan
9/10/2008 2:18:49 PM • Sony KP-46V35 TV • Answered on Sep 10, 2008
KP46V15 Convergence problem
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Gopal
12/13/2007 6:45:07 AM • Sony KP-46V35 TV • Answered on Dec 13, 2007
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered Yesterday
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered 3 days ago
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Circuit diagram of sony kv-sz25m80
str no
2/26/2024 4:44:54 PM • Sony Televison &... • Answered on Feb 26, 2024
I have a Sony Bravia model no klv-22bx350 powers on them shuts down blinks 2times
2 red light blinks can mean a power supply problem that can be caused by a problem on the main board. An authorised Sony repair shop can fix that for you.
2/20/2024 8:03:27 AM • Sony Televison &... • Answered on Feb 20, 2024
Televison & Video Logo
13 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kp 46v15 convergence problem dont
  • Televison & Video
