20 Most Recent Sony KV-35V35 TV Questions & Answers
8answers
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
2/7/2016 2:43:47 PM • Sony KV-35V35 TV • Answered on Feb 07, 2016
I have an LG 55ZW5300 the television went into "slow motion" then the screen went black, the sound still works but nothing else
Its D/A converter is faulty. Contact the authorized service centre for Sony. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
3/21/2014 10:50:28 AM • Sony KV-35V35 TV • Answered on Mar 21, 2014
0answers
Screen is blurred with horizontal lines when 1st turned on. Goes away after 15 mins. Also black cloud appears on screen....moves around then disappears after a few mins. What is going bad?
The fault should be with its supply voltage to video output section circuit. Check this voltage. Check the smoothing capacitor used there. The video output card stage, can be located at the back [neck] of the picture tube, will directly plugged on to it; and can be pulled back out gently. Take care. http://electronicshelponline.blogspot.com/ Check this link for more details. Pull up older posts.
11/24/2013 11:33:31 AM • Sony KV-35V35 TV • Answered on Nov 24, 2013
2answers
There is a small black box in the right corner and
Hello
In your TV [PIP] is on I thinks. Press the PIP button on your remote control repeateadly to ellimite this window. OK.
2/12/2013 6:09:53 AM • Sony KV-35V35 TV • Answered on Feb 12, 2013
Standby
it sounds like it may be ur picture tube or one of the small tubes in back or possibily a fuse i would say fuse
6/9/2012 12:18:25 AM • Sony KV-35V35 TV • Answered on Jun 09, 2012
Air conditioning technician made a
If you can't find one, it won't be of any consequence, the electrician will buy you a replacement.
Why not repair the power supply in your set?
1/1/2011 1:27:23 PM • Sony KV-35V35 TV • Answered on Jan 01, 2011
At first it was lots
Hello
You have stated that your TV has a lot of horizontal lines before it went off picture. We say that lines as retrace lines. So many of them will there on the entire screen, at about one inch or so apart, horizontaly scattered along with picuture. At that time, you may be unable to down the brightness control also. Even though you have reduced the brightness control to zero position, there will be some brightness level on the screen. You should have to repair that fault at the begining. There is a voltage going to the picture tube base, known as screen voltage. That voltage determine the emission of the picture tube, and we call it a bias voltage. When it goes higher than normal, this trouble ie retrace lines will occur. In long run it may spoil the picture tube itself. I don't know what the case of yours.
Anyway it is best for you to consult an experience technician in this case. Ok.
11/5/2010 6:21:44 PM • Sony KV-35V35 TV • Answered on Nov 05, 2010
2answers
Is there a fuse that blows
G'Day,
Yes,there is a fuse that can blow.
The fuse is located on the G board, the power supply, and is marked F601. it is rated 6.3 amp 125 volt. The Sony part number for this is 1-576-193-11. If you find it to be blown, take the old fuse with you to any electronics hobbyist store and they will be able to assist you with the correct type.
What are your symptoms that lead you to believe the fuse has blown. Do you have any lights up at all?
Be sure to disconnect from the Mains power at the wall socker before you do anything. This set has voltages internally that can kill you.
regards
robotek
8/13/2010 4:54:22 AM • Sony KV-35V35 TV • Answered on Aug 13, 2010
My Sony Trinitron Mod KV35V35
A power surge seems to be the cause of the problem. The first thing to replace would be the main fuse on the power supply board(usually 6A or 10A). Replace it and see if it resolves the issue. It is right next to where the power cord goes into the board.
7/19/2010 12:42:13 AM • Sony KV-35V35 TV • Answered on Jul 19, 2010
0answers
Heard noise then tv shutdown and now no power.
fuse has blown.replace with exact same size.you may be lucky.
1/24/2010 6:27:13 AM • Sony KV-35V35 TV • Answered on Jan 24, 2010
2answers
Sony KV-35v35 no power
Bad Picture tube,and Flyback transfomer, shorted hori output.
1/24/2010 1:47:39 AM • Sony KV-35V35 TV • Answered on Jan 24, 2010
Screen blinks
Your picture tube is just about to go. This is a common problem with older Sony's. You will eventually see it go out and not come back. You may want to start looking for a new set. Thanks
11/2/2009 1:09:27 AM • Sony KV-35V35 TV • Answered on Nov 02, 2009
Recently the picture my Sony flat screen TV has
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long) when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
10/19/2009 7:08:20 PM • Sony KV-35V35 TV • Answered on Oct 19, 2009
3answers
Sony KV35V35 TV
Im sorry to tell you my freind, these sets are so common for the tubes to cause this problem.. The repair guy should have told you that they shot the tube and there is no warranty on a repair such as this.. Do yourseld your wife and your wallet a favor. get rid of this set as they will string you along so far till you get fed up. Again no disrespect intended at all. Just some freindly insite. Good Luck Please do not forget to rate this thread.
8/26/2009 6:09:14 AM • Sony KV-35V35 TV • Answered on Aug 26, 2009
Kvg21q1 no picture no sound and led not standby power on........
That's correct. As you have no picture and no sound, you need to replace flyback and power transistor.
What i would advise you that you can purchase the flyback and Horizontal output resistor online and you can also fix it yourself. That would help you save certain bucks.
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
4/22/2009 11:22:53 AM • Sony KV-35V35 TV • Answered on Apr 22, 2009
Lost manual for Goldstar 19" TV
Another person was able to program.
Thank you for your service.
1/28/2009 8:19:20 AM • Sony KV-35V35 TV • Answered on Jan 28, 2009
I have a Sony Trinitrion
unplug the television overnight.
1/24/2009 1:37:04 AM • Sony KV-35V35 TV • Answered on Jan 24, 2009
Televison & Video Logo
Popular Tags
40 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
fuse blows
  • Televison & Video
