20 Most Recent
Sony DHG-HDD250 200-Hours Video Recorder Questions & Answers
DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
Tv guide listings at wrong time
Check the time zone setting in the STB. If after the power cut the STB
settings got scrambled they could have defaulted to the wrong
timezone. This would make the program guide times wrong.
Guide listings are incomplete
1. Manually scan all channels on your TV with your TV remote and write down the channels and network shown:
(sample: 119.2 C-SPAN2 digital channel).
2. Go to Edit Channels and find the icon for C-SPAN2 (about icon 261 in my zip code). Manually change the channel from Off to On, Insert the frequency, and optionally insert the number you want the channel to show in your channel listing ( or move it manually later).
I have about 10 to add each time I reset my recorder.
TV Guide onscreen is the wrong time
I've had this problem before, and always fixed it by going through setup again, setting the zip code to another zipcode nearby, and turning it off overnight. By the next morning the time has fixed itself. This is the only thing that has worked for me consistently.
Stuck in demo mode
to deactive demo mode press menu on the remote...then w/that screen up push the screen mode little gray button at the top of the remote...note that this will not change anything on the screen...i know weird huh...now type in the numbers 9012 you should now be at a new menu the top opption is demo mode...choose it and then choose on or off...good luck i see this i an old post but i hope it helps someone...
