20 Most Recent
Sony DVP-CX777ES Multi-disc DVD Player Questions & Answers
Sony dvp-cx777es
when you say wont load up do you mean you cant insert dvd or do you mean,wont read,impossible to give you a cure without more details of fault
My Sony DVP-CX777ES player
Please check door mechanism as explained in chat session and possibly loading belt and/or door switches could be culprit and causing problem.
Hope this will help.
Thanks.
My Sony dvp-cx777es won't play
I Fixed Mine!!! I found that the part that spins and reads the dvds was bad. Luckly i had a spare changer at home to test this. I took it apart and got this info from the part that i replaced.
KHM-2
90AAA
07666HA
514659
Hope this helps
DVP CX777ES video output features
What you describe it's called image corruption and it's typical of a failing tube/s for a failing CRT tv projector, not an dvd player. But if you're sure that the fault is ion the player then it's a faulty video output stage and processor - it's no longer capable of delivering the levels needed for the high brightness parts of the image . This can be fixed only by replacing the entire mainboard on which the processor is soldered - practically impossible to find on such an old one.
So, by default, you will need to replace it.
Escient Mx-531 won't see Sony DVP-CX777es
I had this problem and I found out that the cable I had bought that fit both the Escient and Sony changer wasnt the right one. I went to Fry's and bought one that said null modem on it and file transfer. Then it found the changer and all started coming together
