20 Most Recent Sony DVP-NS50P DVD Player Questions & Answers
anyway, which device do u use. and have u tried vob format, it seems that u need a dvd format
Sony DVP-NS50P... | Answered on Apr 10, 2019
i have same problem checked fuse was ok. Just went to turn on and system was dead. I would like to get some basic voltage values I could probe the power supply for.
Sony DVP-NS50P... | Answered on Dec 16, 2015
I use warm soapy water (Washing up Liquid) does a super job when errant friends have mishandled my collection. Rinse and wipe very gently (from the Centre outwards) being ever so careful not to scratch them. Make sure completely dry before inserting back into the player.
Sony DVP-NS50P... | Answered on Mar 02, 2015
Hi dvd has a problem with the video section processor .before we go their try this swap the video cable pin may be is just the pin that has poor contact. if nothing change the whole mother board this my last solution .
Sony DVP-NS50P... | Answered on Feb 12, 2014
Likely your player is overhaeting. Put a small fan next to it if you feel its hot from the top.
Sony DVP-NS50P... | Answered on Aug 17, 2013
It works for NS50P, NS575 and the most models of the families NS50 e
NS500.
With the DVD player turned off(stand by), press:
TOP MENU
CLEAR
POWER
Choose option 2 and after option 4. Type:
12450 [press enter]
00000 - Then press enter and power off.
DVD will now be region Free.
Sony DVP-NS50P... | Answered on Feb 12, 2013
Download the user manual to this set. It will have all details. To downlaod it, click here.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
Site is listed with Google. You can locate it either at the bottom part of first search page, or at the top of second page.
Sometimes, one among the advertisements by the side and bottom of each post might help you to get details about the availability of spare parts and other components.
Sony DVP-NS50P... | Answered on Jun 03, 2012
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Sony DVP-NS50P... | Answered on Jan 18, 2012
Please check the type of disc that you're playing.
Generally, if the NTSC format disc being played in PAL Player or vice versa will cause this issue. Please use the NTSC format disc in NTSC player and PAl disc in PAL player.
Please check if the Player is connected to the display device with the correct cables and to the correct jacks.
Please make sure to connect the Component OUT (Red, Blue, Green cables) to the Component IN (Red, Blue, Green).
If you are using the Compiste connection (Yellow, Red and White), please connect the Video OUT of the Player to the Composite or Video IN on the TV using the Yellow cable and Red and white for audio according to the color codings.
Please try with different jacks on the TV to confirm if the issue is with the Jacks on the TV.
Please try power resetting the TV and check if that helps.
Turn off the Player.
Unplug the Player power cord from the electrical outlet.
Let the Player remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the issue is still unresolved, the Player needs to be Serviced at the Authorized Service Center.
Sony DVP-NS50P... | Answered on Jul 17, 2011
hi,
You have to check the try loading belt of you dvd. if the belt is loose or broken the will not be ejected. you can see only OPEN in the display. You can simply check is it related to belt. Power on the dvd player and then press the eject button. Place you ear on the top of the player and listen is there is any humming sound (sound of motor running). If you hear the sound then the belt have some problem.if there is no sound then the problem is related to the electronic part which drives the motor. if so you have to change the mother board of you dvd player. Because the all the parts in it are smd( surface ***** device) also the availability of the part is very rare. Also you have to consult the sony authorized servicing center to repair the same.
If you here the sound then you Can rectify the problem by replacing the belt. Normally you cant see the belt from the top of the mechanism. Because it is beneath the tray. you can see it only if the tray is in eject position.
Remove the top cover of your dvd player. As it is sony dvd player you can eject the tray manually. for that watch the bottom of your dvd player. You can see a slot closed by a plastic strip just bottom of the mechanism. Pull out the plastic strip. Watch through the slot. you can see a Noach which you can move manually to the left and right. put a screwdriver in it and pull the Noach to the side. the try will get ejected. Not fully but partially. You have to pull out the tray fully manually.
If you closely look at the inner end side of the try then you cn see a motor and belt. if the belt is loose it will be in there in the motor pulley and in the wheel. if its broken broken then you have to find it where it . Take the belt as sample and bring a new one. you will get the belt at any of the electronic spare parts shop near you. Put the new belt in the position. inset the tray by pushing it in to inside slowly. power on the dvd player and the press the eject button.
ok
Sony DVP-NS50P... | Answered on Apr 29, 2011
http://www.docs.sony.com/release/DVPNS50-41P.pdf
Page 24 shows instructions on how to play a disc
Sony DVP-NS50P... | Answered on Mar 02, 2011
Sony DVP-NS50P DVD Player Logo
97 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
need hook up dvd player new sony
  • Televison & Video
