20 Most Recent
Sony DVP-CX995V Multi-disc DVD Player Questions & Answers
The player is playing cds get error message that
hello,
the problem of the layer is that the strength the lense needs to carry out work on a DVD is not enough, therefore the lense is weak, though it plays cds, cos the strength needed to play a cd is low.
the solution is for you to unscrew the player, detach carefully and disconect the old lense, and replace with a new lense. screw it back and make sure there is no tampering with any of the wires, then test it with a DVD cd.
SONY DVD-CX995V "cannot play"
In that symptoms optical block (lens) sounds defective and requires replacement.
Let me know if you want to replace optical block by yourself to provide you more technical info.
Sony DVP-CX995V Test Mode
Thought I could add a few suggestions for anyone else experiencing this issue.
1.The SLIDER AT THE TOP OF THE REMOTE MUST be in the DVD Position. The sequence will not work if remote slider is in Disc explorer mode or TV mode. It doesn't specify this in the service manual either.
2. Sometimes it just doesn't work the first couple times, so keep trying. For best results, do the sequence from about 5 feet away, pointing the remote at the receiver on the player (lower left), and slowly and firmly press each button, pausing 1/2 to 1 second between each button press works best for me.
3. Also, it could just be low batteries in the remote and If it still doesn't work and it is worth putting more $$ into try a new remote as suggested already.
Just my 2 cents probably worth noting for future visitors to this question.
4. + LINK to FULL FREE Service Manual
SONY DVP CX995V SM Service Manual free download schematics eeprom repair...
NOTE: at the link above Click the
Get Manual under the preview to download
