20 Most Recent
Sony DVP-NS715P DVD Player Questions & Answers
Will not play DVD, makes rubbing noise when DVD
If it has a paper label on it That can cause the rubbing sound. Is it only this one DVD or will non play? Try using a cleaning disk to remove mess from the laser eye, as well as cleaning this problem disk with a suitable disk cleaning kit
remove any paper labels if it is possible
Please rate my help++++Thanks for uisng FIXYA
Can not play disc
You can try a lens cleaning kit. If it is the kind that comes as a disc all it will do is lightly brush the lens which may not remove all the debris. If you disassemble the player you can easily get to the laser lens. It will usually be fairly accessible once you remove the DVD case. Sometimes it may be located within another box that needs to be disassembled before you can gain access to the laser. The laser unit will be located on a rail system and will have a small clear lens about the diameter of the eraser on a pencil. You can gently clean it with a cotton swab and lens cleaner or rubbing alcohol works just as well. Try that first before buying the lens cleaning kit or replacing the player.
Where is the ir senser on a dvp725d
It should be in the dark plastic area. Shine a flashlight in there and look for the IR receiver. You should see it easily. Otherwise, take the remote and get a piece of card board and cover the entire plastic area. Then start aiming the remote and clicking it to do something it can do. When the IR receiver is uncovered it will do something. Remember the area and shine the falshlight in there and you will see it.
Locked Disc Tray
This is one of those fixes that makes you feel really stupid. We called Best Buy (where we purchased the system) and they told us to unplug the DVD player and plug it back in again. It worked! Duh!
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
