20 Most Recent Sony DVP-NS330 DVD Player Questions & Answers
Turn on the Sony Bluray disc player - BDP-S280. Press and hold the play button for 10 seconds. It should display unlock on the front panel display. You can lock by pressing and holding the play button for 10 seconds again.
Sony DVP-NS330... | Answered on Feb 15, 2013
Locked?
You mean disc tray wont eject?
Sony DVP-NS330... | Answered on Aug 20, 2011
hi the reason why your sony player doesn't work to the samsung monitor is that the file format that compatible to the samsung LE32a336 has PAL system which the sony player that you bought is originated at france which use SECAM system. system are not compatible can not recognized the signal correctly. what you need is a multi system tv unit .
Sony DVP-NS330... | Answered on Jul 09, 2011
The Problem is in Laser eye assembly, you can attempt to clean the plastic lens but you must take the unit apart in order to get at it, Q tip with dab of rubbing alcohol, clean lightly in a circular motion and allow to dry for several minutes, if there is no change replace the machine.
Sony DVP-NS330... | Answered on Dec 20, 2010
connect the player to the TV using an composite(yellow, red and white) cable. Then, select the correct input in the TV. If you are using a Sony TV, then you can select the input by using either TV/Video or Input button.
Sony DVP-NS330... | Answered on Jul 26, 2010
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
Sony DVP-NS330... | Answered on May 15, 2010
U can't mix LG DVD player from Europe with the USA LCD or any orther tvs,because European have different format regions.The format for European are PAL format.The US format are NTSC format.That why ur LCD tv said not supported.
Nope Copy and paste to your browser.
http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=9090
Sony DVP-NS330... | Answered on Nov 06, 2009
DVD player will play DVD disk according to assigned region code.
You can see DVD-NS330 region code at rear of player, where model and serial number is written, region code would be written in globe mark.
Sony DVP-NS330... | Answered on Mar 02, 2009
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Sony DVP-NS330... | Answered on Jan 12, 2009
I think you solved your own problem. If your not getting enough power then one of the symptoms of not having enough power is not powering on, weird behavior, or a weak power light.
Sony DVP-NS330... | Answered on Jan 11, 2009
Sony DVP-NS330 DVD Player Logo
26 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony dvpns330 bought in france will not
  • Televison & Video
