20 Most Recent
Sony DVP-NS355 DVD Player Questions & Answers
Cannot play
1-check the cd it most to be clean
2-turn on the dvd
3-if is on, replace the spin motor , locate in the mechanism. if no on. replace the power supply.
4-if it dont work, replace the lens flex.
Dvpns355 won't play american dvds
Check at back of player for region 1 code written in globe image, if region code is other then 1, this player wont playback American DVDs
Thanks.
How to unlocked
Try these Two Methods.
Multi-Region:
- Turn On the unit with the remote controller
- Wait until "no disc" appears in the unit's display
- Press Pause, 3, 1, 4, 1, 5, 9
- The word "CODE" should appear in the display
- Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
- Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
- Put the player into Standby mode
- Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
- Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
- Press Audio and Return for auto-switching On
- Press Angle and Return for MacroVision On
- Press Subtitle and Return for MacroVision Off
Hope this Helps you out if it does then please leave a thumbs up
Cheers
Little Dish Fitter
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
If your Sony Bravia KLV-32V400A TV is turning on with a green pilot light but there is no picture, there could be several potential causes for this issue. Here are some detailed explanations and potential solutions:
Check the input source: Ensure that the TV is set to the correct input source. Use the remote or the buttons on the TV to cycle through the available input options (e.g., HDMI, AV, Component). Sometimes, the TV may be on the wrong input source, resulting in a blank screen.
Check the video cables: Verify that the video cables connecting your TV to external devices (e.g., cable box, DVD player) are securely connected. Ensure that the cables are not damaged or loose. Try using a different set of cables or connecting to a different input port on the TV to see if the issue is related to the cables or the specific input.
Adjust display settings: It's possible that the TV's display settings are not properly configured. Using the remote, access the TV's menu and navigate to the display settings. Ensure that the brightness, contrast, and other picture settings are properly adjusted. You can try restoring the default settings or adjusting the settings to optimize the picture quality.
Perform a power cycle: Turn off the TV and unplug it from the power source. Wait for a few minutes, then plug it back in and turn it on. This can help reset the TV's internal components and potentially resolve any temporary issues.
Reset the TV to factory settings: If none of the above steps resolve the problem, you can try performing a factory reset on the TV. Keep in mind that this will erase any customized settings and restore the TV to its original factory settings. Refer to the user manual for instructions on how to perform a factory reset.
Contact Sony customer support: If the issue persists after trying the above steps, it's recommended to contact Sony customer support or consult a professional technician for further assistance. They will have access to specific troubleshooting steps and can provide guidance based on the model and technical specifications of your TV.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
