20 Most Recent Sram Red Questions & Answers
Hi, my front mech wont change smooth. It is a compact chain set. From new it would never change like it should. takes lots of time and peddling to change.I
If not too late return it to the place that sold it to you and request it be fixed to work properly. Otherwise take to a bike shop or bike co-op. Alternatively go to Repair Help or Sheldon Brown Bicycle Technical Information to learn how to fix it yourself I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
11/11/2017 2:22:20 AM • Sram Red • Answered on Nov 11, 2017
Slow and tight Sram red Crank
I'm sorry, but if you don't know how to order the correct BB or properly install it you should not be building a bike from scratch, as this is probably the first of many problems you will have. As for YouTube it's not a reliable source of technical info. Try this site: http://www.parktool.com/blog/repair-helpOR Contact the frame seller and find out what BB the frame takes or contact the seller of the BB and ask for assistance. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
7/28/2017 5:28:13 PM • Sram Red • Answered on Jul 28, 2017
2answers
The front derailer on my sram red compact just wont change quick!
Which brand of shifters are you using? A SRAM derailleur won't work with Shimano shifters and vice-versa. So - first; if you are using SRAM shifters with the Red derailleur - then changing to Shimano will not solve your issue but only make it worse. If however you have Shimano shifters - then this is a good solution.The Red derailleur should not shift that poorly with SRAM shifters. It is not the best - but it's not bad. If I had the bike in a repair stand I would be looking carefully at the following after affirming that the shifting system was indeed all SRAM:
  • Derailleur cage height relative to the large chanring - should be a maximum of 2 mm
  • Derailleur cage should be aligned as close to parallel to the rings as possible
  • Derailleur upper and lower limit screws should be adjusted within spec and in order to allow the derailleur to travel the correct amount for ideal shifting
  • Derailleur cable tension should be correct.
Hope this helps... Let me know if you need more.
3/2/2015 10:20:58 PM • Sram Red • Answered on Mar 02, 2015
0answers
Front derailer shifting problems scram red
the shift wire that goes into the derail-er might need to be pulled a little more loosen the nut that holds it tight and then pull the cable some then tighten the bolt back up and do different variations on that till it rides and shifts smooth
3/15/2013 10:55:02 PM • Sram Red • Answered on Mar 15, 2013
I need to see a
9/13/2021 2:20:09 AM • Sram Cycling • Answered on Sep 13, 2021
Today while riding with sram force group set in the small chain ring in front while shifting to the smaller cogs in the back cassette there was alot of chain slack to the point that the chain was not
Riding small-small is called cross-chaining, and is not recommended. On a double chainwheel bike at least the smallest and sometimes the next smallest should not be used. On a triple it's more like the 3 smallest. Nevertheless, the derailleur pulleys should take up the slack at least, if you have not made any changes to chain or derailleur. The spring on the pulley cage may be broken or weak. You need to get in-person help at a bike co-op or bike shop. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
2/17/2018 12:06:07 AM • Sram Cycling • Answered on Feb 17, 2018
0answers
0answers
Grip shift max
Be the first to answer 5/24/2013 3:31:57 AM • Sram Cycling • Posted on May 24, 2013Be the first to answer
0answers
2answers
I have the sram xx
Yeah, derailleurs are sold as a complete unit, just replace it.
8/26/2011 1:27:21 AM • Sram Cycling • Answered on Aug 26, 2011
Chaning shifting cable on x9.
A simple web search for "sram x9 cable replacement" finds procedures.
8/25/2011 10:40:13 AM • Sram Cycling • Answered on Aug 25, 2011
Sram Red Logo
9 questions posted
Top Sram Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Sram Cycling Expert? Answer questions, earn points and help others
View Most Popular
Sram Cycling
  • Sram Cycling
Most Popular Question
front derailer shifting problems scram
  • Cycling
