20 Most Recent
Samsung ES75 Digital Camera Questions & Answers
Software es28
If you don't have the CD with intelli-studio, you could try some free software like Photoshop Express, Ulead, Gimp, BeFunkey, Perhaps these packages also can download pictures from your camera.Most drivers your computer needs, are in the modern operating systems. Only when you have Win 2000 or elder, you need drivers from the CD. Perhaps some elder MACs need drivers too from the CD that came with the camera.
Download software
You don't need any special software in order to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Transfer pics pc easyshare
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
Why did my camera suddenly blackedout?
Try doing some hardware resets and such, if it doesn't work then and it's highly indicative of being a hardware problem I suggest getting it to someone who can fix it for you or replacing it.
How do i unlock my memory card
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
How do i lock my memory card?
SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
