20 Most Recent
Panasonic SC-HT650 System Questions & Answers
My SC-HT650 system reads F61.
Not the transformer. probably needs a voltage ic or output ic. F61 is a voltage error code. if it was the power tranformer it would not power up at all. It also could be just a bad fan. The fan should start as soon as you turn it on.
11/14/2015 7:43:09 AM •
Panasonic...
Answered
on Nov 14, 2015
My Panasonic is Model# SA-ht650.
The
For others, the fan on this model only runs with the volume turned way up, to test it unhook the speakers and play something like the radio with the volume set to 0dB, the fan should run.
6/28/2015 6:12:57 PM •
Panasonic...
Answered
on Jun 28, 2015
Reading code f61
pop cover plug in with med to light pressure on the heat sink press down gently and push one way just a tad , press power , see how long to shut down. do same other direction. what you should find is that the solder connections are bad and need to be redone. this is not the first pan. that has had this problem, some of there other stereos do to.
2/25/2015 3:56:42 AM •
Panasonic...
Answered
on Feb 25, 2015
We bought a new Panasonic high definition TV
So what's different? The TV. Anything else like the video type (s-video, composite, component)?
Perhaps if you described what cable is carrying video and the point-to-point connection to the TC-L42D2 we'd understand what isn't working.
1/16/2011 9:40:42 PM •
Panasonic...
Answered
on Jan 16, 2011
When i connect my panasonic sc-ht650 to my
Sounds like your tv doesn't have componant video in, just composite video. Try the yellow video out on the dvd player to the same video in on the tv. The red and white on the tv is for audio left and right.
11/25/2009 10:49:14 PM •
Panasonic...
Answered
on Nov 25, 2009
Won't read dvd or cd
The laser needs to be replaced. Part is available from tritronicsinc.com. Good Luck!
barneyluc
10/5/2008 8:01:28 PM •
Panasonic...
Answered
on Oct 05, 2008
Instruction Manual
yes, search panasonic web site and hope you will get instruction manual there.
7/27/2008 2:24:55 PM •
Panasonic...
Answered
on Jul 27, 2008
DVD player is "LOCKED"
Well, at least the child-lockout works, right?
I have a similar Pan. HT system and I suspect you will have to go through the main menu and look for settings regarding 'tamper-proofing' to prevent just such 16 month-olds from inserting their jelly bread into the DVD player.
Your system may differ from ours but you should be able to find that feature in your user manual.
If the manual is gone, you might want to try this page:
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems.list.75434
Your system is not listed directly but there are several from that series and they may share features.
Downloading of the manuals costs nothing.
Good luck-
3/6/2008 1:44:27 AM •
Panasonic...
Answered
on Mar 06, 2008
Unit will not turn on.
I think we have the same problem only mine is flashes an F61 on the display then shuts itself off.
12/26/2007 11:16:24 AM •
Panasonic...
Answered
on Dec 26, 2007
Panasonic SC-HT650
from what i heard this is a common problem with this unit (mine included). apparently it cost more to fix than buying a new one.
11/28/2007 8:06:14 PM •
Panasonic...
Answered
on Nov 28, 2007
Remote control
http://www.xdiv.com/remotes/ never know, it might help.. remember, if you do find a code, all the buttons may still not work. Your better off just buying a replacement on ebay or amazon.. you'll be surprised.. you might find it there.
11/6/2007 12:43:37 AM •
Panasonic...
Answered
on Nov 06, 2007
