20 Most Recent Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Questions & Answers
IC 1006 is faulty on the DG board thats for 53TW models other models it means LOW DC voltage. If you need further info please let me know.
Panasonic... | Answered on Mar 26, 2018
No I have not read of any other issues like this.
Panasonic... | Answered on Feb 28, 2017
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Panasonic... | Answered on Dec 18, 2014
I have this same issue. Did you ever figure out what was going wrong and how to fix it?
Panasonic... | Answered on Nov 04, 2014
Easy fix. I had the same green dot problem and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
JK
Panasonic... | Answered on Sep 15, 2014
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Panasonic... | Answered on Dec 02, 2012
That board will be hard to find. But the power indicator should blink a series of blinks when it doesnt power up the number of blinks will indicate where the problem is thats preventing the set from powering up. If you let me know the number of blinks I will assist with the problem.
Panasonic... | Answered on Oct 27, 2012
my tv panasonic PT-53TW53G turn on red light on tv no pictur on sound
Panasonic... | Answered on Oct 12, 2012
If none of the connections on the set work look for a menu on the unit in the owner manual for the PS3---it may be a selectable setting in that that is causing this problem--also try the PS3 on another set to make sure it is ok.
Panasonic... | Answered on Jun 15, 2012
Have set not work and power light blinks 3 times?
Panasonic... | Answered on May 25, 2012
Your part# for the lenticular screen is TKG2AH50641. Panasonic has them new for $358.65 plus shipping. Or you might be able to find one cheaper if you google it or find someone that has the same model TV that doesn't work anymore.
Panasonic... | Answered on May 18, 2012
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Popular Tags
331 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
power light panasonic pt 53tw53 blinks 5
  • Televison & Video
