20 Most Recent
Panasonic PV-DF2004 20 in. TV/VCR/DVD Combo Questions & Answers
DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
9/30/2019 2:19:52 AM •
Panasonic...
Answered
on Sep 30, 2019
My panasonic tv dvd vvcr
Return the universal remote,if all ur tv universal codes of ur tv on the owner manual,don't work.Try website like Remotes.com to buy the tv original remote or very close capatible to it.Yes,it cost double even tripple the prices of any niversal remotes,but these remotes are 100% it will work with ur tv,because it the same or compatible as a orginal remote would.
1/5/2014 10:50:02 PM •
Panasonic...
Answered
on Jan 05, 2014
Panasonic tv, vcr, dvd combo gets black rectangle
There should be a closed caption button on your remote control. You will want to go into the CC settings and turn off the TEXT mode as that is whats causing the black box to appear. Please take a few moments to rate my answer.. Thanks..
11/26/2009 5:44:28 AM •
Panasonic...
Answered
on Nov 26, 2009
DVD player
Its posibal your dvd not rogins the informations is tiping of dvd
12/24/2008 3:42:12 AM •
Panasonic...
Answered
on Dec 24, 2008
Audio
how to change the sound siestem from 6.0 to 5.5
11/10/2008 5:41:06 PM •
Panasonic...
Answered
on Nov 10, 2008
Remote code
Some remotes, such as the Sony RM-VL600, have a learning function that will "learn" the code for your set. I used one for my combo unit, and it worked OK for the TV functions, but I couldn't get it to work for the DVD player.
7/12/2008 1:55:53 AM •
Panasonic...
Answered
on Jul 12, 2008
Codes
i need the answer to! someone please post!!
3/28/2008 4:51:29 PM •
Panasonic...
Answered
on Mar 28, 2008
Horizontal line on screen
The most common problem would be a bad solder joint on the vertical drive IC. It could also be a bad solder joint on the flyback transformer, as it supplies voltage to the vert. stages. If you disassemble the set, please be careful not to get shocked. Discharge the high voltage stages as a precaution.
Geno
2/26/2008 9:11:37 PM •
Panasonic...
Answered
on Feb 26, 2008
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
8/6/2007 4:42:02 AM •
Panasonic...
Answered
on Aug 06, 2007
No audio
try to reprogram the channel. it seems that your tv's sound circuit is fine.
5/4/2007 8:55:56 PM •
Panasonic...
Answered
on May 04, 2007
