20 Most Recent Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo Questions & Answers
in most cases you need to unplug over night then the code would be reset to factory 0000 when it starts back up.
Panasonic... | Answered on Jan 02, 2018
Closed captioning is either enabled/disabled as part of initial set up or by operation of a CC button on the remote control.
Panasonic... | Answered on Mar 02, 2016
Maybe your dvd laser is dirty or faulty
Panasonic... | Answered on Aug 07, 2014
my dvd plays cds but not dvds. Any help is welcome!
Panasonic... | Answered on Sep 19, 2013
Check and replace the remote sensor inside it. It might be faulty.
5_4_2012_2_05_25_am.jpgThese are images of some types.5_4_2012_2_05_39_am.jpg
Panasonic... | Answered on May 04, 2012
It depends on the remote. Some will handle combination TV/VCR/DVD units; others do not. The other issue is the age of the remote. Remote codes are limited to those for devices released 6 months or more before the remote was programmed. Since it was listed at Amazon in Feb 2004; I'd recommend a remote programmed in 2005 or later.
A guaranteed remote is available here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12970443361250&smodel=PVDF2704&brand_pn=PANASONIC_PVDF2704 . The universal remotes that are programmed via a USB connection with a computer will be the easiest to program. I can't recommend a remote for you. I will recommend that you read the fine print for any given remote (the cheapest ones are most often not able to work with combination TV units).
I hope this helps.
Panasonic... | Answered on Feb 07, 2011
Hello
Just select a PHILIPS CL034 UNIVERSAL REMOTE CONTROL. Panasonic is listed in its codes. Codes are
............ 0718 0416 0007
........................... 0618 0807 0039 0739
........................... 0345 0696 0901 0608
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Each remote has its own set of codes and supports only a very limited number of tv models. If your tv isn't listed then your only option is to try all the other codes listed for the manufacturer (Panasonic in your case) in the hope one of them will work. If none of them work that the remote isn't supporting it, simple as that.
Panasonic... | Answered on Jun 08, 2010
http://service.us.panasonic.com/OPERMANPDF/PVDF2004.PDF
http://www.nodevice.com/manual/newmans/panasonic/PV-DF204NASVCzip/get27160.html There above is a service manual, this will help you isolate and possibly repair More than likely it is the laser head assembly, as it usually is, this can be replaced relatively cheaply, if parts can be obtained, this is what you need a service manual to get the part numbers. You could also just replace the entire DVD unit, as that;s some times easier and less expensive.
http://www2.panasonic.com/consumer-electronics/support/TV-Combos/model.PV-DF2704
Panasonic... | Answered on May 11, 2010
Tries wash all ur DVD Disc with dishing soap to clean out all the smushes,grims,oil from the finger prints,on the laser surface of the disc,it should play now.Not than u must take the tv aparts take some Q tips with some rubbing alcohol to clean the DVD laser eye it self.Long time DVD laser eye reader have contaminate from the air cause it not read discs.Especially house hold that smoke or live in dries heat states.
Panasonic... | Answered on Apr 14, 2010
Press the audio button to move the arrow downwards.
Panasonic... | Answered on Mar 28, 2010
Although the TV is digital, the market has not dumped the analog compatibility (yet). You can connect your VCR through the RF input, using channel 2, 3 or 4 (depending on your VCR) to view your video collection. Or, you can connect your VCR by RCA cables to the composite video input. Most TVs now have only 1 or 2 composite inputs (Yellow, White, Red). They are sometimes shared, serving as a component input as well (Green, Blue, Red, White, Red). For these TVs, you will notice a yellow circle or some other marking around the Green connection indicating that it is also a composite input. When connecting to such an input, remember to connect the white (and red if your VCR has one) to the white (again, red applies) to the audio input jacks of this video input. I hope this was of some assistance and not too confusing.
Panasonic... | Answered on Mar 23, 2010
Check scart pins aren't bent over. Also make sure DVD not in Progressive scan mode.
Panasonic... | Answered on Mar 03, 2010
Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo Logo
54 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
dvd player play dvds
  • Televison & Video
