20 Most Recent
Panasonic PV-C1321 13 in. TV/VCR Combo Questions & Answers
Vcr lock activated
Hi There,
Try unplugging it, wait 2 minutes, then plug it back in. Let me know if it clears.
1/24/2013 2:29:02 PM •
Panasonic...
Answered
on Jan 24, 2013
I have a Panasonic TV/VCR combo my kids deleted
A universal remote can be programmed for your tv/vcr. Then you can access the menu to auto program your tv. Otherwise there should be a button on the front that allows you to access the menu and then auto program the unit.
2/19/2009 12:20:04 AM •
Panasonic...
Answered
on Feb 19, 2009
Loss of picture and sound repeatedly
You already hit the nail in the head,the problem might be the actual conector loose inside the set or the tuner has loose conections to the main board,the shell of the tuner is the ground make sure the conections are solid,if you are familiar with tv service this will help but if you are not too familiar be safe and call for help,right now it should not be expensive.
10/13/2008 2:47:27 PM •
Panasonic...
Answered
on Oct 13, 2008
Cable connection
the v hold is going out that causes the picture to roll if only 1 channel does that then call the cable company.If it's more than one then find the v-hold in the back and turn it slowly till it stops,if it gets faster turn it the other way
10/6/2007 1:43:12 AM •
Panasonic...
Answered
on Oct 06, 2007
Audio on recorded tape
you could try a wet type tape head cleaner but I doubt if that will help but it couldnt hurt. These combo units are built so tight together I wouldnt recomend that you try to open it. I would though look through the front door and look toward the right side and see if something got inserted into the machine and is blocking the audio head. If this dosent get you back audio then you have a curcuit problem and you are gonna need to take her in for an estimate Good Luck
5/15/2006 6:06:15 PM •
Panasonic...
Answered
on May 15, 2006
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
