20 Most Recent Panasonic DMR-E65 DVD Recorder Questions & Answers
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
10/27/2013 10:41:16 AM • Panasonic... • Answered on Oct 27, 2013
How to best connect this DVD recorder to a Sky plus box
can turn it on don't have the code
10/26/2013 4:01:36 PM • Panasonic... • Answered on Oct 26, 2013
0answers
Panasonic DMR-EZ47V combined VCR/DVD has a U61
The service manual says that:
U61 = The unit is carrying its recovery process (with no disk in the tray) . If there is a disk remove it and restart the unit . This is the message that appears when the system's firmware crashed because of an incorrect command - normal operating procedure, just wait for it to finish. If the message doesn't goes away in 10 minutes after a power cycle you should force it: press the Ch UP and Ch DOWN buttons until the DVB Auto-Setup message appears on the screen.
If nothing you do has an effect and you haven't done anything to the unit when this message appeared then the fault is hardware - the processor of the unit has failed. The only way to fix that is to replace the mainboard. But that would cost about $175, more than a new unit, so it's time for a new one.
8/29/2011 6:38:08 AM • Panasonic... • Answered on Aug 29, 2011
The recorder keeps on self checking and attempts
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
Clean manually the laser head eye with a cotton bud very softly and without pressing the lens eye.
If there is still no result then watch the CD if it spins or tries to spin. If the head unit moves up or down to focus or in and out of the drive, if so the board seems to work correctly and the possibility of the optical head being the suspected fault is closer.But if any of the above seems otherwise we must recheck with possibilities of the processor board
1/15/2011 6:04:18 PM • Panasonic... • Answered on Jan 15, 2011
What cords and cables do I need to attach my
Audio/video cable or S video cable(depends on ur tv,75 Ohm coaxial cable,
3/9/2010 9:11:42 AM • Panasonic... • Answered on Mar 09, 2010
Dvd keeps
This is a known fault with the Panasonic DMRs. Basically, the main chip in the power supply circuitry starts to fail intermittemntly due to poor design of the heatsink.
If you search FixYa site it will come up many times.
Unless you or a friend can (safely !) identify, handle, desolder and solder electronic components, this is not a DIY repair.
If you can, like I said there are already several really good FixYa fixes for this.
9/17/2009 3:41:15 PM • Panasonic... • Answered on Sep 17, 2009
Search forward button (>>) on DMR-E65 remote inoperational
Carefully pry the remote apart (check for screws). Then you can take a q-tip and some alcohol or Windex and clean any dirt or contamination from the circuit board and the bottom of the button pad. You can some times see rings on the board where the buttons make contact and that is what needs cleaned off.
9/7/2009 10:27:04 PM • Panasonic... • Answered on Sep 07, 2009
Panasonic DMR E65 cycling in self test on start up
Check the IC in the primairy power supply,common fault.
7/22/2009 8:07:23 PM • Panasonic... • Answered on Jul 22, 2009
PANASONIC DMR-E65S
try other types of media- it's possible there's a malfunction in the motor drive electronics.
Re-post with your results
4/6/2009 2:57:40 PM • Panasonic... • Answered on Apr 06, 2009
2answers
PANASONIC DMR-E65S
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image below.
Goodluck...
4/5/2008 9:46:56 PM • Panasonic... • Answered on Apr 05, 2008
Panasonic hds700tds playing audio no videos
  1. Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
  2. Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
  3. Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
  4. Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
  5. Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
  6. Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
  7. Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
  8. Hope this helps
4/9/2024 11:43:10 PM • Panasonic... • Answered on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
  1. Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
  2. Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
  3. Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
  4. Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
  5. Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM • Panasonic... • Answered on Apr 09, 2024
I'm about to lose my mind trying to find the + on a Panasonic remote! Can anyone tell me how to find it? The + is part of my router code to connect my tv to the internet.
Unfortunately there isn't one. The workaround is to change the Router Password or SSID to remove the plus + for something else.
need to input the plus sign for wifipassword XXXXX my ...
JustAnswer https://www.justanswer.com > Network Experts Apr 6, 2014 - How do i type the plus sign for my wifi password on my panasonic viera remote? I also need to input the "+" sign. - Answered by a verified 1 answer ยท Top answer: Okay, great. Go to Network settings on your tv menu> select Wireless ne https://www.google.com/search?q=Panasonic+remote+plus+symbol ..
3/8/2024 5:06:23 AM • Panasonic... • Answered on Mar 08, 2024
Tv diagram tc 2165ga
panasonic tc-2165ga
2/26/2024 11:40:35 AM • Panasonic... • Answered on Feb 26, 2024
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector. Locate the lamp cover on the projector. Remove the lamp cover. Take out the old lamp. Insert the new lamp. Replace the lamp cover. Reset the lamp hours: Press the Enter button to display the "Option" menu. Use the 5 or 6 button to select "Lamp Runtime". Press and hold the Enter button for approximately 3 seconds. The "Lamp Runtime" will change to "Time Reset [Power Off]". Turn off the power and disconnect the power cord. Finally, plug in and turn on the projector. Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM • Panasonic... • Answered on Feb 17, 2024
How do I get my Panasonic television out of self check mode if I don't have the remote?
Question edited for clarity, it is probably a Viera not a Viesta. You can try a power cycle reset. Remove the power plug overnight, press and hold the On button for 60 seconds. Plug back in. All televisions need a remote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
1/31/2024 5:11:57 AM • Panasonic... • Answered on Jan 31, 2024
Panasonic DMR-E65 DVD Recorder Logo
23 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
panasonic dmr ez47v combined vcr dvd u61
  • Televison & Video
