20 Most Recent
Sony STR-DH510 5.1 Channels Receiver Questions & Answers
It can be possible to bi-amp a pair of Klipsch
Bi-amping indicated that you have two amps, one for the tweeters, adn another for the woofer, in a two way system. If you don't have two seperate amps, you can use the speaker A & B outputs to run seperate speaker llines to each set of speaker inputs, but that will not be true bi-amping. Another alternative is to use jumpers to connect the speaker inputs together, this not needing seperate amps. Here's a link to the owner's manual:http://www.manualslib.com/manual/359882/Klipsch-Reference-Series-Rb-41-Ii.html#product-Reference%20Series%20RB-81%20II
When you connect the HDMI cable from the TV to the
You can't connect your receiver to the television to get sound that way unless your television has an hdmi output. Your tv more than likely does not have an hdmi output. Those are hdmi inputs on your television. The way to connect the television to the receiver is to connect the red and white RCA outputs from the tv to the red and white RCA inputs on the receiver to get stereo sound. Now if your television has a digital audio out you might be able to get surround sound with connecting a fiber optic cable between the digital audio out of the tv and the digital audio in on the receiver, but this does not always work for all of the devices you have connected to your television.
The way to go is to connect all of your devices to the television's inputs for video and directly to the receiver for sound. The devices are connected from their audio OUT to your receiver's audio IN.
I have a Sony STR-AV770 receiver that has stopped
your question depends on how good you are at electronic diagnosis (symptom diagnosis) and how adept you are at removing and installing electronc components. first you have to determine why the amplifier has stopped working on the left channel. Make sure that the problem isn't a simple one, take the speakers off the right side and hook them to the left side and see if you get sound. If you do,, then the problem is the left speaker or left speaker wire. If you don't get sound then tyr taking the input that feeds the right channel and pluggin it into the left channel and listen for sound, if you get sound now the problem was the signal from your source not being sent down the left side.
If it still doesn't work you need to move inside the amplfier, but first, get close to the back of the amp and give a sniff, do you smell anything (a pungent burnt wire or rubber smell) if you do, the the chances are good that some components have burned out. Do you recall having a shorted speaker wire on the left side? shorted speaker wires are notorious (especailly older equipment) for burning out the final amplifer stage. If this was an expensive amp it might be worth fixing, if its not worth much then maybe you should consider religating it to use as a monophonic amplifier (one channel) you could use it to power a sub woofer in a hibryd stereo or surround sound system.
I don't know what more I can tell you at this point. If you go through the steps I outlined, and want to tell me the result I shall be glad to respond and maybe give you another direction to head in. good luck and I'm glad you are adventruous enough to want to try.
