20 Most Recent
Panasonic DVD-S25 Questions & Answers
How do I connect my Panasonic DVD player DVD S25 to direct tv?
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not
in the address bar of your browser], and click search. It is an electronic equipments service help
site. All details you want are
there. Note the position of
hyphen in between words in site name, when you type it in. The site will appear as it is in
web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts.
You can get all details.
6/1/2012 2:48:11 AM •
Panasonic...
Answered
on Jun 01, 2012
I tried to connect my Panasonic DVD player (DVD S25) to Direct TV, but it didn't work. Can someone help me do this?
There are codes to setup both devices. Visit this site for more details. Type in the site name
search box [
not
there.
Check the related ads posted by Google along with posts. Sometimes, you might get more details from it.
5/29/2012 5:03:51 PM •
Panasonic...
Answered
on May 29, 2012
El dvd pide un codigo, cual es
You can try this:
1. Turn the DVD player on
2. Hit Setup on the remote control
3. Press 8888
4. Press Next button ( >>' )
5. "Version" menu should show up on the Screen
6. Select "Version" menu, select "Region Code" and choose 0 by pressing the down arrow on your remote.
7. Click Setup to exit
or you can buy it from here:
http://www.multiregionupgrades.com/upgrades/panasonic/dvds25.htmGood luck,
Alex
PS-Don't forget to vote me, thanks!
2/14/2011 11:59:25 AM •
Panasonic...
Answered
on Feb 14, 2011
Dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
4/3/2010 4:57:57 AM •
Panasonic...
Answered
on Apr 03, 2010
I can't get my DVD player to play in color.
HI
As your new tv got a/v inputs if so are the set to the right sty for the country that you live in , uk and eur pal, france secam, and for usa ntsc this can be set from the menu on tv remote
3/19/2010 11:19:57 PM •
Panasonic...
Answered
on Mar 19, 2010
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
2/3/2010 6:23:12 PM •
Panasonic...
Answered
on Feb 03, 2010
Wont play dvd about 2 months old
it could be DIRTY LASER or a spindle motor or defective laser pu
since its 2 months old it probably has 90 days labor and 1 yr parts id look for my reciept and call and find out where to take it to have it looked at
11/9/2009 1:13:21 PM •
Panasonic...
Answered
on Nov 09, 2009
Panasonic dd-s25 won't play dvd.
HI...
Have you tried reg.CDs to see if those have trouble too?
I would say that the lens assembly has got debris or a filmy substance over the lens.
If you're not the least bit technical , dont open the unit.
It will require that the cover gets removed and the top DVD spinner plate gets removed so that the Lens can be cleaned.
The chrome rails that the DVD reader runs on would need cleaing too.
3/4/2009 4:12:13 PM •
Panasonic...
Answered
on Mar 04, 2009
Panasonic hds700tds playing audio no videos
- Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
- Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
- Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
- Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
- Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
- Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
- Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
- Hope this helps
4/9/2024 11:43:10 PM •
Panasonic...
Answered
on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
- Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
- Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
- Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
- Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
- Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM •
Panasonic...
Answered
on Apr 09, 2024
