20 Most Recent Panasonic TH-50PX50U 50 in. Plasma HDTV Questions & Answers
Why are all my inputs, except one are in black & white instead of color?
control board is going bad
5/21/2015 5:12:59 AM • Panasonic... • Answered on May 21, 2015
Flash code
It's a fail safe to save other board inside your set from stray voltage. The error LED code says your PSB Power Supply board has some blown capacitors on it. First try a hard reset by unplugging the set for 4-6 hours. If that doesn't work you need to remove the pack panel and look for the Blown caps on the PSB. Caps should be completely flat (X) top view. Not puffed or bulged. Radio shack harbor freight for a soldering kit with flux and some new thru-hole caps about 2v above your current cap rating. Get them too big and you risk them exploding and they are hard to seat.
5/13/2014 8:17:06 PM • Panasonic... • Answered on May 13, 2014
Power Failure
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Gopakumar Gopalan Google
3/2/2014 9:56:59 AM • Panasonic... • Answered on Mar 02, 2014
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
1/8/2014 6:30:40 PM • Panasonic... • Answered on Jan 08, 2014
Your website does not work properly.
If you want a good website or any kind application then always acquire the services of Allerin. They use powerful Ruby on Rails technology to develop applications. Allerin has many years of experience in application development and has completed many projects. For more information you can always visit http://www.allerin.com/
11/16/2013 7:15:24 AM • Panasonic... • Answered on Nov 16, 2013
How to change picture size on Panasonic th-50px50u
You can press the [Aspect] or [Format] button on the TV remote.
11/12/2013 5:39:21 PM • Panasonic... • Answered on Nov 12, 2013
Had no power
Check fuse and rectifier
7/14/2013 4:57:45 AM • Panasonic... • Answered on Jul 14, 2013
Image does not fit screen.
Change the aspect ratio of the picture by entering the picture adjustment menu. Refer it user manual for more details.
5/29/2013 12:28:32 PM • Panasonic... • Answered on May 29, 2013
2answers
The timer on my panasonic th50px50u is greyed out
I had the same problem. I fixed it by going to menu > setup > restore to default. I had to readjust my picture settings and relabel all my hdmi connections but it fixed the sleep timer.
5/19/2013 2:00:29 PM • Panasonic... • Answered on May 19, 2013
Fix sound card
To fix this problem is really a skilled work. After sound card replacement, you have to enter its service mode option to configure it. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
4/26/2013 4:57:26 PM • Panasonic... • Answered on Apr 26, 2013
I HAVE A PANASONIC 50" PLASMA TV IT HAS A HORIZONTAL 3 TO 4" WIDE LINE ACROSS THE SCREEN HOW DO I REPAIR IT MYSELF
sounds lie a couple bad drive Ics on the buffer boards. You can get replacement buffer boards and free technical assistance from www.tvrepairworld.com
11/28/2012 2:57:11 AM • Panasonic... • Answered on Nov 28, 2012
0answers
Hdmi port out
Be the first to answer 9/22/2012 4:01:14 PM • Panasonic... • Posted on Sep 22, 2012Be the first to answer
When I try to power on the red light flashes then
You Tv is experiencing a issue with its power board. How many times does it flash?There is a squence of flashes to pinpoint where the issue is.Parts would be purchase at www.partstore.com , if you do not know how to fix the Tv you might want to bring it into a shop. Your looking about a $200 repair bill just as it sits.But can you give me how many blinks? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
12/5/2011 11:44:38 PM • Panasonic... • Answered on Dec 05, 2011
0answers
Panasonic TH-50PX50U 50 in. Plasma HDTV Logo
46 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
panasonic 50 plasma tv horizontal 3 4
  • Televison & Video
