20 Most Recent
Panasonic TH-50PHD7UY 50 in. HD-Ready Plasma Television Questions & Answers
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
4/26/2017 10:47:57 PM •
Panasonic...
Answered
on Apr 26, 2017
I have @ panasonic plasma
Hello
Your TV has no direct cable connector. You can connect it to cable via converter using SERIAL (D-Sub 9pin [RC 232] type connector wire from converter to your TV. It is designed so. High Density D-Sub 15 pin connector is used to connect this Tv with computer. OK.
7/21/2011 2:45:55 PM •
Panasonic...
Answered
on Jul 21, 2011
I want to buy a
Manufacture part # EUR646529R. search for that on yahoo or google, and can get a list of sites offering the remote
can buy it on many websites including ebay for around $20 or under
6/7/2011 7:18:48 AM •
Panasonic...
Answered
on Jun 07, 2011
Hello, my TV just went
Does this happen all input modes? Did you try connecting your box or DVD player through component? If not please do it and see if the problem persists. Post back with your results.
Sai.
1/24/2010 3:27:07 PM •
Panasonic...
Answered
on Jan 24, 2010
PLASMA PANEL
THe display is available as part number MD50H07A1J from tritronicsinc.com for $1260. Upon return of the bad panel, you will be refunded $250.
Dan
7/17/2009 10:55:45 AM •
Panasonic...
Answered
on Jul 17, 2009
TV screen turns off, green light stays on
As posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
3/25/2008 3:43:51 AM •
Panasonic...
Answered
on Mar 25, 2008
Need help troubleshooting sudden "no signal" error
T Wiz
3/25/2008 3:41:04 AM •
Panasonic...
Answered
on Mar 25, 2008
TV shuts off
Check for cold soldering connection in the low voltage circuit.if possible there could be a bad filter capacitor.
3/10/2008 1:27:08 PM •
Panasonic...
Answered
on Mar 10, 2008
Game console and plasma displays
You did not list which console you have and what type of cables it has.
Looks like your plasma has:
1 component
1 composite
1 VGA
1 S-Video
If this is an xbox360 or PS3 then you will want to use the component connection, but this one is already used by the cable tuner. Don't worry there is a solution. The xbox360 and ps3 output a higher resolution that your plasma can handle, so use the component with those systems.
If it is an older console, predating the xbox360, then use the composite or S-video connections.
Since you are short on video inputs, you might need a video switch. A switch with both component and S-video connections for future add-ons.
You can find them all over the web, or your local video store like walmart and best buy. Here is a switch i found on ebay that should work:
http://tinyurl.com/3aoev9
here is the ebay search i used:
http://tinyurl.com/2ograc
Make sure you buy extra cables, most of these boxes do not come with cables, so buy what you need.
I prefer video switches that don't require a power outlet, but it's your choice. Some of the powered switches, have remotes for the lazy people, but I don't need anymore remotes on my table, keep that in mind.
2/14/2008 3:28:40 AM •
Panasonic...
Answered
on Feb 14, 2008
