20 Most Recent
Panasonic TC-32LX50 32 in. HD-Ready LCD Television Questions & Answers
Broken screen
all you can do is chase a used Toshiba (Theater Wide HD) Model NO.20HLV86or buy a replacement TV was it covered under contents damage insurance ? this TV has been discontinued the design of this screen means its put together layer by layer .sandwiched ..not just a glass cover a screen replace can't be done unless the Toshiba company "TV parts division " has the exact same screen to supply to your local TV repair man Even finding circuitry boards to be supplied for that model have a slim chance
4/11/2017 5:36:01 AM •
Panasonic...
Answered
on Apr 11, 2017
I need to replace the lamp on panasonic lcd tv
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the top left
corner of the display window. It will
make search easy. Some times, the ads
attached with each posts, both at the right and bottom, might help you to find
the availability of spare parts. There
are more than 700 posts to different brand TVs now. Pull up older posts there.
9/7/2012 7:40:58 AM •
Panasonic...
Answered
on Sep 07, 2012
The cable guy programmed the cable remote to turn
First use the original remote control that came with your tv, or just manually turn it on at the tv itself to bes sure it is working. If it works you should call the tech support for the cable company to program their remote control to a different code - or put it back to to factory state and just use two remotes.
9/15/2009 1:58:52 PM •
Panasonic...
Answered
on Sep 15, 2009
Color seems inverted!!! please help!!!
CHECK OTHER TYPES OF VIDEO INPUTS. IF USING COMPONENT VIDIO CHECK YOUR CABLES ARE ALL MAKING GOOD CONNECTION, YOU CAN USE AN AUDIO CABLE TO CECK INDIVIDUAL COMP. VID. CABLES TO MAKE SURE THE CABLES ARE GOOD.
4/13/2009 7:31:48 AM •
Panasonic...
Answered
on Apr 13, 2009
My broken screen
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor
http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
5/4/2008 2:27:08 AM •
Panasonic...
Answered
on May 04, 2008
