20 Most Recent
Panasonic TH-37PE30 37 in. Plasma Television Questions & Answers
Want to remove from stand
hi try this site this www.retrevo.co.uk this where you can download the user manual this will help you take the stand off good luck
regards
shaun
1/3/2014 8:04:26 PM •
Panasonic...
Answered
on Jan 03, 2014
BBC channels change to BBC
I don't have a solution but I would like to add that I am having the same problem which started quite recently (April 2011). Phone Panasonic UK support (0844 844 3852) they were very helpful. They haven't solved the issue yet but I guess the more people recording the same complaint gives them increased diagnostic information. I wonder if this is localised to a particular transmitter? My local transmitter is Bilsdale.
6/30/2011 10:51:27 AM •
Panasonic...
Answered
on Jun 30, 2011
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
2/8/2010 5:03:02 PM •
Panasonic...
Answered
on Feb 08, 2010
CAN TH-37PE30 37IN BE CONVERTED
For a short answer - no.
It requires a new tuner, cards, and larger power supply.
The cost of conversion far outweigh the price of a new unit.
Thanks fo rusing FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
11/30/2009 5:28:59 PM •
Panasonic...
Answered
on Nov 30, 2009
Buzzing
The noise is caused by dust on one of the toroidal transformers(usually a round looking thing with wire wound around it). Go to the back of your television and try
and pinpoint were the sound is coming from. Turn your television off and blow it out with compressed air if it is close to air vents in the television. If you cant see it you might have to open your television back panel.
5/1/2009 4:31:42 AM •
Panasonic...
Answered
on May 01, 2009
