20 Most Recent
Panasonic CT-34WX54 34" TV Questions & Answers
Green Spot On Screen
IN your statement says tv is second hand and also you tried degausser method also. The problem is permanent magnetic field affected your tv set. So the best recovery is fix one button magnet in the affected area.
1/31/2014 4:59:16 PM •
Panasonic...
Answered
on Jan 31, 2014
Panasonic ct-34wx54. I cant remove
Try pressing the volume down button on the T.V. and the info button on the remote. Do this for at least 5 seconds and it will reset the T.V.
3/18/2011 7:33:46 PM •
Panasonic...
Answered
on Mar 18, 2011
I dont have a remote for my tv and it wont turn on
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
10/10/2010 5:25:26 AM •
Panasonic...
Answered
on Oct 10, 2010
Will not power on
Check the main A/C fuse. These sets are famous for blowing the fuse. It is usually a 6.3 amp. Look at fuse to confirm size. Thanks for using fixya.
3/3/2010 12:54:06 AM •
Panasonic...
Answered
on Mar 03, 2010
After having my dish network upgraded to HD and
Sounds like one of the cables got plugged in wrong.
Look at the back of the HD box and there should be a cable with 5 ends on it (Green,Blue,Red, White and Red).
Often times a flashlight can help make sure you see the colors clearly.
The Green,Blue and one of the Reds is for video. The White and other red are for Audio.
When you unplug the connector the connection it is attached to is also colored. Check to make sure the colors on the cord match the color they are connected to at the box.
The most common mistakes connecting these cables are:
1) Crossing the Green and the Blue cables.
2) Connecting the Red Audio cable to the Red Video connection.
If all of the connections match the correct colors find the same cable where it plugs into the back of the TV and check these connections that they are correct.
When you find and move the cable to the correct connection this should clear up your color and you can begin to enjoy your new toys....
Good Luck....
1/15/2010 6:37:15 PM •
Panasonic...
Answered
on Jan 15, 2010
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
4/22/2009 4:58:13 AM •
Panasonic...
Answered
on Apr 22, 2009
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
11/4/2008 7:49:21 AM •
Panasonic...
Answered
on Nov 04, 2008
TV won't turn on
It may be too late for this advice, but if you live in a lightning prone area, you should consider having a 'whole house surge protector' installed.
The cost should be well under $300 (a lot less if you install it) and with the included insurance (most often for $25,000) it is a good investment.
If your house was struck, I'm surprised you don't have a list of things that no longer work.
It could just be an expired TV.
8/6/2008 12:53:13 AM •
Panasonic...
Answered
on Aug 06, 2008
My picture was distorted by a speaker magnet
well , yes , you have to purchase a DEGAUSSING COIL to take care of this problem and know how to use it (which its very easy) available at electronic stores (try EBAY) What you do is you place the DEGAUSSING COIL in front of the color spot and do circular motions while slowly stepping away from it . that should take care of that.
4/16/2008 12:48:09 AM •
Panasonic...
Answered
on Apr 16, 2008
