20 Most Recent Panasonic CT-34WX52 34" TV Questions & Answers
Picture too dark
Hi kseguin Your TV has internal problem @ video stage on the circuit But you may try to apply resoldering on the circuit board near flyback and CRT circuit board.
1/17/2014 11:24:36 AM • Panasonic... • Answered on Jan 17, 2014
A BLACK SQUARE APPEARS IN THE MIDDLE OF THE SCREEN HOW DO I GET RID OF IT
Hi Tony You`ve mentioned that ON CERTAIN CHANNELS THE TV WORKS FINE, so your trying to say that not all channels THE BLACK SQUARE APPEARS IN THE MIDDLE O THE SCREEN... my be that black square is generated from the broadcast center. may be your unit is good. let me ask you how many channels that your tv works fine..?
1/16/2014 10:02:53 AM • Panasonic... • Answered on Jan 16, 2014
manual
The power light comes on and the screen makes the
You have a bad powersupply in this tv that would need to be fixed or replaced.
I would assume its a bad capacitor inside that is proventing its power up you can correct me if I am wroung , as I am not there physically to see the unit but this is what a bad capcitor would do.
Please leave postive feedback for your free answer today. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
11/6/2009 4:03:37 AM • Panasonic... • Answered on Nov 06, 2009
Panasonic hds700tds playing audio no videos
  1. Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
  2. Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
  3. Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
  4. Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
  5. Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
  6. Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
  7. Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
  8. Hope this helps
4/9/2024 11:43:10 PM • Panasonic... • Answered on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
  1. Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
  2. Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
  3. Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
  4. Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
  5. Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM • Panasonic... • Answered on Apr 09, 2024
I'm about to lose my mind trying to find the + on a Panasonic remote! Can anyone tell me how to find it? The + is part of my router code to connect my tv to the internet.
Unfortunately there isn't one. The workaround is to change the Router Password or SSID to remove the plus + for something else.
need to input the plus sign for wifipassword XXXXX my ...
JustAnswer https://www.justanswer.com > Network Experts Apr 6, 2014 - How do i type the plus sign for my wifi password on my panasonic viera remote? I also need to input the "+" sign. - Answered by a verified 1 answer · Top answer: Okay, great. Go to Network settings on your tv menu> select Wireless ne https://www.google.com/search?q=Panasonic+remote+plus+symbol ..
3/8/2024 5:06:23 AM • Panasonic... • Answered on Mar 08, 2024
Tv diagram tc 2165ga
panasonic tc-2165ga
2/26/2024 11:40:35 AM • Panasonic... • Answered on Feb 26, 2024
How to reset lamp for Panasonic PT-vx400nt?
Turn off and unplug the projector. Locate the lamp cover on the projector. Remove the lamp cover. Take out the old lamp. Insert the new lamp. Replace the lamp cover. Reset the lamp hours: Press the Enter button to display the "Option" menu. Use the 5 or 6 button to select "Lamp Runtime". Press and hold the Enter button for approximately 3 seconds. The "Lamp Runtime" will change to "Time Reset [Power Off]". Turn off the power and disconnect the power cord. Finally, plug in and turn on the projector. Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
2/17/2024 12:59:14 AM • Panasonic... • Answered on Feb 17, 2024
How do I get my Panasonic television out of self check mode if I don't have the remote?
Question edited for clarity, it is probably a Viera not a Viesta. You can try a power cycle reset. Remove the power plug overnight, press and hold the On button for 60 seconds. Plug back in. All televisions need a remote. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
1/31/2024 5:11:57 AM • Panasonic... • Answered on Jan 31, 2024
On the Panasonic DMR-EZ47V, it had a VCR tape stuck in it, when turn on shows, F60, now doesn't show anything.
Yes bad caps on the video processing board according to the links
SOLVED: F60 error on Panasonic DVD recorder - VCR
iFixit https://www.ifixit.com > Answers > View > F60+error... Oct 8, 2014 - Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board ...
I have a DMR EZ485 that shows an error code of F60. What
JustAnswer https://www.justanswer.com > Electronics Question Jan 5, 2018 - The F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ... 1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Panasonic DMR-ES40V Drive and F60 Code
AVS Forum https://www.avsforum.com > threads > panasonic-dmr... Oct 26, 2014 - F60 is a result of a low or missing voltage on the digital board. Often the culprit would be capacitors that have leaked. But first try a "cold ...
Another Capacitor Failure, Another Fix
EE Times https://www.eetimes.com > another-capacitor-failure-a... Jan 21, 2019 - An online search revealed that F60 was a general failure code, usually caused by a failed aluminum electrolytic capacitor. Time to get the ...
Picked up a Panasonic DMR-EZ475V that throws a code ...
Reddit · r/VHS 2 comments · 2 years ago The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
My Panasonic DMR-ES40V DVD/VHS player now says " ...
JustAnswer https://www.justanswer.com > recorders-and-players Dec 23, 2012 - F60 is a general error code indicating a failure on the video processing board. First try a "cold boot". Unplug the recorder again, allow it to ... ..
1/30/2024 3:40:50 AM • Panasonic... • Answered on Jan 30, 2024
Panasonic Television 58". I need to sign in on it?
Question edited for clarity. I doubt your television id 58 FEET (58') You don't give the model number or what you are trying to sign into? WiFi, Netflix, Cable, Parental Controls? Here are some manuals
Owner's Manual - Panasonic
Panasonic https://help.panasonic.ca > OperatingInstructions PDF Model No. TC-58EX750C. TC-65EX750C. TC-75EX750C. Owner's Manual. 58"/65"/75" Class 4K Ultra HD TV* ... by the television manufacturer and has a safety. 30 pages
Operating Instructions
Panasonic https://na.panasonic.com > ... PDF You need to subscribe to a cable TV service to enjoy viewing their programming. ... Check the input signal compatible with this TV. (see page 52 - 53). Page 55 ... 58 pages
Model No. TH-42PX600U TH-58PX600U - Panasonic
Panasonic https://help.panasonic.ca > viewing PDF • Has the battery run down? • Has the TV POWER button been turned On? • To operate external equipment of other manufacturers, register the remote control ... 35 pages
Unable to access detailed TV menu (Panasonic)
HiFiVision.com https://www.hifivision.com > ... > Television Apr 22, 2022 - Hi guys - I have a weird problem. I have a 58" Panasonic LED TV purchased a couple of years ago (TH-58HX450DX... .
12/31/2023 5:04:05 AM • Panasonic... • Answered on Dec 31, 2023
I need help My Panasonic VHS/DVD Recorder will only record Standard Play Does Anybody know how to fix it?
Help in the link. Probably wrong media being used. https://www.google.com/search?q=Panasonic+VHS%2FDVD+Recorder+will+only+record+Standard+Play Full 'make model (what it is)' in all questions as first 3 words please. ..
12/27/2023 1:05:29 AM • Panasonic... • Answered on Dec 27, 2023
How to get the riding off of bottom of a Panasonic 55 inch big screen
'riding'? Or do you mean 'writing'? What does it say? Things like this are part of the settings menu, go to it and Exit out of it. Or Google make model manual ..
12/20/2023 1:20:12 AM • Panasonic... • Answered on Dec 20, 2023
How do you reset a UN 55C 7000WFX2 a 55 ounce Panasonic big screen
Panasonic?
12/19/2023 9:37:35 PM • Panasonic... • Answered on Dec 19, 2023
I have a Panasonic TV it has sound but no picture of can't even get menu to come on please help
Age and model number may help you get an answer.
12/17/2023 5:59:39 PM • Panasonic... • Answered on Dec 17, 2023
I have a Panasonic DVD recorder who's remote died so I purchased a One For All URC3661 to replace it, only to discover it has no delete key. How do I delete unwanted programs? Thank you.
I would purchase an original or use the `magic' key as delete after teaching the key what to do.
12/16/2023 6:16:40 PM • Panasonic... • Answered on Dec 16, 2023
Need to access menu on Panasonic viera without remote
If you need to access your Panasonic television's menu and you don't have a remote, then your best option is to use the physical buttons on the television itself. There is a MENU button, often on the back of your Television.
12/11/2023 9:37:19 AM • Panasonic... • Answered on Dec 11, 2023
Panasonic CT-34WX52 34" TV Logo
Popular Tags
4 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
picture dark
  • Televison & Video
