20 Most Recent
Panasonic CT-32SX12 32" TV Questions & Answers
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
9/7/2009 11:41:15 PM •
Panasonic...
Answered
on Sep 07, 2009
Television died
Unplug the set, remove the back and follow the power cord onto the main board, where you will see a small glass fuse. Replace that fuse with a new GMA 6.3 amp fuse. I have seen many of those fuses in Panasonics "pop" for no apparent reason. If that does not fix it then replace the back and have the set serviced by an experienced tech.
12/2/2008 1:47:42 AM •
Panasonic...
Answered
on Dec 02, 2008
Philips TV model number 27PT543S37A
TV turns on but doesn't stay on goes in and out then blank screen. LED light stays on during the entire time
your problem is called hunting
you can check power supply of your tv .It common problem in Philips T.V.
Thanks
7/6/2008 12:21:38 AM •
Panasonic...
Answered
on Jul 06, 2008
3year old Panasonic ct-32sx12f dead?
Sure, Why not?
It is worth the effort.
If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems.
It could be a simple blown Fuse, or the Power Regulator IC.
This should not cost you more than $100-150 as Technician charges + 15-20$ for spares.
It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100.
definitely worth calling a professional techie
6/27/2008 12:50:20 AM •
Panasonic...
Answered
on Jun 27, 2008
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
3/18/2008 9:50:35 PM •
Panasonic...
Answered
on Mar 18, 2008
TV does not turn on
I'm looking for the same info... my CT-32sx12f is completely dead too. I was wondering if the IC regulator or the flyback is bad. Fuse is fine.
Anyone have any wisdom or experience on these sets they can interject?
Thanks!
9/21/2007 2:48:51 AM •
Panasonic...
Answered
on Sep 21, 2007
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6.
it is due to cable signal ie weak.
now there is no sound
this is due to sound section
1 loose connect in sound section
2 speaker
3 problem in sound section some part must have failed.
9/20/2007 6:22:42 PM •
Panasonic...
Answered
on Sep 20, 2007
TV failure
I would say it is in the power supply circuit. check the 145 v line I do not suspect the problem in the video section.The 145 volts feed to the flyback.
6/11/2007 7:01:28 PM •
Panasonic...
Answered
on Jun 11, 2007
Circuit board
try wwww.ptscorp.com they might be able to help you.replace the power supply of ypour tv it have a short with a diode or the regulator.if you cannot do it yourself take it to a tech.
3/23/2007 8:26:48 AM •
Panasonic...
Answered
on Mar 23, 2007
Fuse keeps blowing
NEVER EVER replace a fuse and think that va fuse will blow all by itself. The fuses are there to protect the set from catching on fire incase theres a short inside the set. Now in some cases an intermittant short can work after you replace the fuse but if its burnt black or brownish, theres a short inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifyers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted
9/7/2006 2:14:33 PM •
Panasonic...
Answered
on Sep 07, 2006
