Hi.
Don't know what happened to the last post I sent you its
disappeared.
What I think you should do is definately replace the CRT white socket (tube base plug).
You can either take the CRT number from the label on the tube & put it in to google then search for Crt base plug.
Or see if there is A repair shop local to you who can order the tube base for you.
Are you definately sure the arcing is external to tube & not happening in the tube neck ?
Is the CRT made by LG / PHILIPS. These are notorius for for arcing over internally I must write at least 1 A week off for this problem.
If you can still run the set try tapping the neck of tube with screwdriver handle if pic flashes or goes predominately1 colour you are looking at the tube with internal short.
If this is the case there are ways of trying to get rid of the internal short let me know what you find ?
http://dysonmanuals.llc.nu/
Chris...
