20 Most Recent Olympus Stylus Stylus Tough 8010 / mju Tough- 8010 Digital Camera Questions & Answers
2answers
I am having trouble downloading photos to PC from
Having gone two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
12/2/2012 2:11:58 AM • Olympus Stylus... • Answered on Dec 02, 2012
IPICS ON SD CARD DO NOT SHOW ON PLAYBACK OLYMPUS 8010
Many cameras will only display pictures taken by that camera (or at least the same model). Also, if a picture has been edited in any way (opening a pic in a photo editor and saving it without making any changes counts as editing) then the camera will not display it.
2/25/2012 4:56:42 PM • Olympus Stylus... • Answered on Feb 25, 2012
0answers
0answers
Tough
Be the first to answer 12/16/2011 11:51:08 PM • Olympus Stylus... • Posted on Dec 16, 2011Be the first to answer
Curved lines on playback screen and prints. Monitor screen is fine. Is it repairable?
Get a quote some cameras cost more to repair then to replace.
7/10/2015 1:39:57 AM • Olympus Stylus... • Answered on Jul 10, 2015
Olympus stylus 1 just froze with lens extended. I took battery and card out for 2 hrs. and still no power.
Try this, set the dial to P, then open the battery door and then press the Menu button and OK button together for about 5 seconds. If you see something in the screen like Olympus? Then press the Menu and OK button together again for another 5 seconds, this is a hard reset and hope it fixes your problem?
12/14/2014 1:29:18 AM • Olympus Stylus... • Answered on Dec 14, 2014
Why is my Camera stuck on and beeping, screen blank
Lens is out of correct possition.
7/31/2014 7:22:48 PM • Olympus Stylus... • Answered on Jul 31, 2014
Why camera says one moment and does not seem to want to recognize computer
Most brands of cameras deliver a CD with the camera, containing software, needed to backup, transfer and work with the pictures you shot, to a computer. Most of the time there is software is for both, Windows and MAC. Before you connect the camera to any computer, you should install the software. The disk also has the drivers for the old operating systems. If you lost the CD, or just don't know where it is right now, you can go to the site of your camera brand and try to download the software you need. For that look under support. If your camera is old, and the brand does not exist anymore, try a freeware picture transfer / editing software pack. Like Gimp or Adobe Photoshop elements. Just connecting a camera to a computer causes two things. The camera shuts down, and the computer won't recognise the camera. So nothing works. If you can't get software form your brand, you always can install other generic software like Ulead, Pixir, BeFunkey, Gimp, Photoshop express. Or if that is not possible you could install an external memory card reader and download the pictures via de memory card reader.
6/21/2014 4:08:28 PM • Olympus Stylus... • Answered on Jun 21, 2014
Pictures will not download into pc
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
4/20/2014 2:54:40 PM • Olympus Stylus... • Answered on Apr 20, 2014
Weird spots on camera screen
go out and purchase you some LCD tv screen cleaner and use that. It is safe to use on the camera screen, see if that fixes the problem.
4/16/2014 6:27:08 PM • Olympus Stylus... • Answered on Apr 16, 2014
Cannot remove battery
The type (model) of battery in use will determine the solution; For most commercially available, consumer products, using a grounded (rubber/non-conductive handled screwdriver) is often enough to pry it loose. If extremely stuck, feeding a small length of twine or string between the battery and the device and pulling gently should be able to pry it loose. For other rechargeable batteries (cell phones, MP3 players, etc.), you may have to find a way to insert a tool or string into the space for the battery. Cheers.
4/7/2014 9:12:58 PM • Olympus Stylus... • Answered on Apr 07, 2014
Programming mode
I could copy the pages, from the manual, but why should I do that? you better read what is in the manual, direct. I could make an error while typing it from the manual.
3/6/2014 7:28:59 PM • Olympus Stylus... • Answered on Mar 06, 2014
Olympus Stylus Stylus Tough 8010 / mju Tough- 8010 Digital Camera Logo
11 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Stylus Olympus
  • Stylus Olympus
Most Popular Question
am having trouble downloading photos pc
  • Cameras
