20 Most Recent
Denon AVR-1911 Receiver Questions & Answers
While watching satellite tv, receiver will work
Sometimes equipment gets too hot and starts glitching. Try an improve cooling and air circulation. Often standing the thing on one end so it's tall will help keep it cool. See if it goes for longer with better cooling.
I con not get the surround sound to work. It only
The AVR-1911 is an A/V receiver with HDMI version 1.4a that can be connected to TVs and other devices that support 3D video such as Blu-ray disc players, game consoles, and set-top boxes. This receiver supports not only Dolby TrueHD, DTS-HD Master Audio and other HD Audio formats but also Dolby Pro Logic IIz for enhanced vertical and horizontal spatial performance at the front, the essence of 3D acoustics complementing the excitement of 3D video. The AVR-1911 comes with numerous other features such as 1080p up-conversion to give you a sharp, high-definition picture from DVD and other standard video sources, and a Glow-key remote control unit that is easy to use in the dark, to maximise your home theatre experience. Check if the RCA connector is properly connected.. Sometimes the problem is in the CD or DVD itself. Try to go to www.denon.com. ty
How can i connect headphone
Hi rnazarians,
The
headphone jack is being inserted in the "
PHONE" jack of this unit. When the headphones are plugged into this jack, audio will no longer be output from the connected speakers or from the
PRE OUT connectors. Please see image below.
--> You may also use the
HDMI port to connect the unit to your TV using an
HDMI cable.
Hope it helps.
Thank you for using FixYa.
Size of fuse for Denon dra 697
The Denon DRA-697CI stereo receiver typically uses a 250V, 2.5A fuse. However, it's always a good idea to consult the user manual or check the label near the power input on the device itself to confirm the exact fuse size and specifications for your particular model. Using the correct fuse size is important for safety and to prevent damage to the receiver. If you're unsure, you can also contact Denon customer support for assistance.
Fuse size for Denon DRA 697 c!
The Denon DRA-697CI is a stereo receiver. Typically, the fuse size for electronic devices like stereo receivers is listed in the device's manual or on a label near the power input. It's important to use the correct fuse size to ensure proper protection against electrical faults.
Without specific information about the fuse size for the Denon DRA-697CI, I recommend consulting the device's manual or contacting Denon's customer support for accurate information. Using the wrong fuse size can potentially damage the device or pose a safety hazard, so it's crucial to verify the correct specifications.
