20 Most Recent Sony CFD-S05 Radio Boombox Questions & Answers
0answers
I have a Sony CFD-S05. The radio, CD and Cassette
their is a good chance the amp or volume control has failed, the only other possible cause is that the headphone socket has got something inserted to cut the sound or has failed try plugging headphones in if still no sound, its a fail end of life for item hope it helps a little
11/22/2013 9:45:38 PM • Sony CFD-S05... • Answered on Nov 22, 2013
I need a replacement antenna for a sony radio
Antennas can be easy to find, but size may be not so easy Ebay is your best bet for a low cost However if you are not to bothered a simple thin piece of wire cello taped on to what is left should work just as well, recommend about 2 m of wire any thin wire will do as there is no current in the connection If you do go down the route of replacing the antenna and have the original connector still sticking out where the screw goes threw your fine - or if its gone complete you should fine a small screw either at the base or the side casing, this should release the connection to the unit, however if not you will need to open it up antenna cost about 4 - 7 quid depending on size, but as before if your happy to use a thin wire it should work just as well, or salvage a similar size one off a old radio etc... there will not be any sony parts for this its just a telescopic antenna used on many items hope this helps a little
11/22/2013 9:42:50 PM • Sony CFD-S05... • Answered on Nov 22, 2013
Auvio remote code for sony cfd s05
HelloGet into this link. You can download the user manual to this set from here. OK.
12/23/2011 5:36:52 PM • Sony CFD-S05... • Answered on Dec 23, 2011
Sony PS-FL7 direct drive turntable. When start button is pressed it illuminates but turntable won't rotate. All other functions work as they should.
'Direct Drive' appears to mean something different to Sony unless the belt is for another function. https://lptunes.com/products/sony-ps-fl7-ii-ps-fl7-ii-psfl7-ii-turntable-tonearm-belt-replacement Service Manual
Sony PS-FL7 Stereo Turntable System Manual
Vinyl Engine https://www.vinylengine.com > library > sony > ps-fl7 Sony PS-FL7 owners manual, service manuals and schematics are for reference only and the Vinyl Engine bears no responsibility for errors or other inaccuracies. "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(56px);"> Rating: 8/10 · ‎ 4 reviews
SONY PS-FL7 service manuals download
NoDevice https://www.nodevice.com > ... > Vinyl Players > SONY SONY PS-FL7 service manual (Vinyl Players) in PDF format will help to repair SONY PS-FL7, find errors and restore the device's functionality. ..
4/6/2024 7:54:41 PM • Sony Audio... • Answered on Apr 06, 2024
My sony icf-cl75ip wont turn on and is making a clicking sound. How can I fix this?
There is not reason this would click and not turn on. If it just clicked, it would likely be caused by interference from another appliance, typically a fridge or freezer. The most likely reason is a relay in the internal power supply. It will need a Sony Service Centre. https://www.sony.com/electronics/support/res/manuals/4154/41545841M.pdf It isn't a recorded known issue. Sony are high quality equipment so it is worth getting it fixed. https://www.google.com/search?q=sony+icf-cl75ip+clicks+and+not+working ..
4/6/2024 2:59:06 AM • Sony Audio... • Answered on Apr 06, 2024
Hello Sir. My Sony Deck MHC RV-900D Stereo, it's front panel is not working. I changed the fuse, replaced it but after no response. Please Help me Sir, Thanks.
Open it up and look for bulging or split electrolytic capacitors, especially in the back to the display and the power supply. Or take to an electronics technician for diagnosis. https://www.google.com/search?q=Sony+deck+MHC+RV900D+not+working ..
4/3/2024 2:34:25 AM • Sony Audio... • Answered on Apr 03, 2024
Sony Music system error code display c81, what is minig
C81 error indicates an internal hardware fault.Check CD mechanism is not jammed.
3/3/2024 7:36:52 AM • Sony Audio... • Answered on Mar 03, 2024
Sony Audio Rack SU-S5520. Need a power cord for it please?
Question edited for clarity, turned around plus CAPS. It should be a standard figure 8 connector. https://www.google.com/search?q=sony+audio+rack+su-s5520+power+cord+replacement ..
3/1/2024 8:31:36 PM • Sony Audio... • Answered on Mar 01, 2024
I need code for Sony MHC VX33 sound IC
STK402, IC501. Part number 8-749-016-96
2/23/2024 6:13:11 PM • Sony Audio... • Answered on Feb 23, 2024
Sony mhc-gnz888d is on standby and wont power on
Standby problem solved
2/19/2024 4:08:20 PM • Sony Audio... • Answered on Feb 19, 2024
Why is my Sony DZ- 840K Home Theater displaying "Please Wait" like for ever, without loading to play anything. Please I need an urgent remedy to this problem.
You realize we are Fixya dot com and we aren't Sony Support? We don't do 'urgent remedies' although we do try to help for free. https://www.google.com/search?q=Sony+DZ-+840K+Home+Theater+displaying+%22Please+Wait%22 I wrote this Fixya Tip which you can try first. https://www.fixya.com/support/r29927004-dvd_player_or_cd_player_not_reading ..
2/9/2024 5:57:26 AM • Sony Audio... • Answered on Feb 09, 2024
I have a Sony stereo system PS-LX47P. The turntable has stopped working, I have changed the belt,but still not working. Can any Sony turntable be used to replace it?
The record deck is known as a PS-LK47P. If you wish, another deck will work as long as it has a magnetic cartridge and no preamp built in. A Technics SL-1200 is the sort that is fine and a definate upgrade.
1/30/2024 7:38:29 PM • Sony Audio... • Answered on Jan 30, 2024
Sony CFD-S05 Radio Boombox Logo
10 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony cfd s05 radio cd cassette
  • Audio Players & Recorders
