20 Most Recent Samsung SL502 / PL55 Digital Camera Questions & Answers
You can download the instruction manual for your Samsung PL55 Camera by clicking on the following link.(http://downloadcenter.samsung.com/content/UM/200909/20090930142030843/PL55_PL57_English.pdf ).Hope this helps.Your valuable feedback would be appreciated.Thanks
TinuAlbinAlex
Samsung SL502 /... | Answered on Sep 26, 2019
See if you can access the menu and format the card to see if the card is damaged.
Samsung SL502 /... | Answered on Mar 18, 2016
They can but there is an inherent issue with those cards. They are RAM memory and can be easily damaged by a lot of things. Static electricity is one downfall of them.
Samsung SL502 /... | Answered on Mar 17, 2016
To connect to the computer, you should first install the software on the computer that is on the CD, that came with the camera.
See page 88 of the manual.
Samsung SL502 /... | Answered on Oct 30, 2013
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Samsung SL502 /... | Answered on Oct 03, 2012
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Samsung SL502 /... | Answered on Aug 02, 2011
Do you really need a driver?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Samsung SL... | Answered on Mar 26, 2014
Sounds like defective switch assembly.
Samsung SL... | Answered on Jan 25, 2013
Hi - You can download the manual by clicking the link underlined in blue below:
samsung S850
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Samsung Cameras | Answered on Oct 29, 2019
I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site;;: http://Geosalary.com
Samsung Cameras | Answered on Oct 24, 2019
Can you explain what you mean in more detail, please ?
Samsung Cameras | Answered on Oct 10, 2019
You can download the Quick Guide and the User Manual from the bottom of the page at
http://www.samsung.com/us/support/supportDownloadCenter.do?prd_ia_cd=N0000112&prd_mdl_cd=EC-SL502ZBDBUS&prd_mdl_name=SAMSUNG+SL502
Samsung Cameras | Answered on Sep 26, 2019
Ebay has a usb/charger for a Samsung E63. Item No. 120530514745, for £13.99p. It also has a list of compatible cameras, therefore any of the mentioned cameras usb cable should be compatible with a E63.
Hope this helps.
Samsung Cameras | Answered on Sep 23, 2019
In the menu setup 2, go to "format" option an click yes. for more information read the user manual in this direction
http://downloadcenter.samsung.com/content/UM/200803/20080324103057703_English.pdf
Samsung Cameras | Answered on Sep 19, 2019
Samsung SL502 / PL55 Digital Camera Logo
17 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
SL Samsung
  • SL Samsung
Most Popular Question
got samsung pl55
  • Cameras
