20 Most Recent Samsung ES60 Digital Camera Questions & Answers
Are they an option offered in the menu system to assist in obtaining level horizons, or are they random ? If the latter, then the LCD in the viewfinder may have connection problems or broken circuits. Has it been dropped or knocked recently? Was it subject to extreme temperature etc ? You may find the lines shift around or even go away for some time. That again would imply bad connections.
Samsung ES60... | Answered on Sep 21, 2016
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
Samsung ES60... | Answered on May 02, 2014
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Samsung ES60... | Answered on Feb 22, 2014
Try setting up your Samsung es60 on flash mode to turn on flash
Samsung ES60... | Answered on Jan 09, 2014
Do you really need the Samsung software?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Samsung ES60... | Answered on Oct 29, 2013
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Samsung ES60... | Answered on Mar 26, 2013
You don't need any software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Samsung ES60... | Answered on Nov 12, 2012
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Samsung ES60... | Answered on Aug 28, 2012
when i take picture no flash
Samsung ES60... | Answered on Aug 19, 2012
use the common sense and logically and proceed:
memory card/battery cover open
2) batteries loaded with wrong polarities
3) batteries with NOT full charges, replace with FULL charged
4) batteries are NOT the same type, replace
5) poor contacts between camera vs battery terminal, clean the contacts with isopropyl alcohol.
God bless you
Samsung ES60... | Answered on Aug 03, 2012
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Samsung ES60... | Answered on Jan 17, 2012
Samsung ES60 Digital Camera Logo
41 questions posted
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
ES Samsung
  • ES Samsung
Most Popular Question
camera screen lines
  • Cameras
