20 Most Recent
Celestron NexStar 114GT (269 x 114mm) Telescope Questions & Answers
Focus knob on Celestron NexStar 5 does not appear
Does the focuser move in and out when you turn the knob? If it does then go outside during the day timne and practice focusing on a distant object. Use the eyepiece with the biggest number written on it.
This will give you the lowest magnification-- which is easier to focus.
6/16/2011 5:47:40 AM •
Celestron...
Answered
on Jun 16, 2011
How do i conect my
You need to buy a USB-to Serial adapter cable like this one:
http://scopestuff.com/ss_usbr.htm
scopestuff.com sells these. The Keyspan brand USB-Serial adapter is also a good one.
5/28/2011 5:50:26 PM •
Celestron...
Answered
on May 28, 2011
I have celestron brand 114mm
Usually the lens cap just pops off -- the bottom where the mirror is located should not be removed.
These scopes do NOT have screw on lens caps. ?
5/9/2011 8:13:52 PM •
Celestron...
Answered
on May 09, 2011
The motor controller of by
Only Celestron will have that part. Contact them here:
http://www.celestron.com/c3/page.php?PageID=37
2/25/2011 2:35:00 PM •
Celestron...
Answered
on Feb 25, 2011
I have a celestron nex star 114gt and the tripod
You can try and contact Celestron directly-- and or a Celestron dealer. Here are two links:
http://www.celestron.com/c3/page.php?PageID=37 Celestron
http://www.optcorp.com/ a Celestron dealer
10/23/2010 4:01:31 PM •
Celestron...
Answered
on Oct 23, 2010
I just bought a used
Can you see something in the distance during the daytime?
Did you do the training, set the TIME
Did you do a two star alignment?
You must follow the setup procedure exactly for the scope to have accurate gotos.
Get the manual out and read it several times. You can practice inside just to get familiar with how the scope operates.
9/7/2010 7:38:37 PM •
Celestron...
Answered
on Sep 07, 2010
Hi, Bought a used telescope with a GT mount. The
This scope does NOT need to be polar aligned --
Here is the manual:
http://www.celestron.com/c3/images/files/downloads/1228334587_nexstargt.pdf
This is an ALT AZ goto scope. Read the manual above. You use the hand controller to move the scope in Altitude and Azimuth(left-right).
You must align it on 2 stars in order for it to has successful gotos.
8/22/2010 12:56:40 AM •
Celestron...
Answered
on Aug 22, 2010
Why is the cap at the end smaller thna the
Yes, that's the point of it.
Remove the entire (full diameter) cap for stellar and planetary viewing, or just the smaller diameter central cap for viewing the Moon which is far brighter and is too bright without either adding a neutral density filter or by partially masking the optical tube assembly.
2/24/2010 10:37:54 PM •
Celestron...
Answered
on Feb 24, 2010
Azimuth Drive failure on Nexstar 114
Hi Dan, before you ship it off somewhere, you may want to try and change out the hand controller with another one that someone has and see if the problem moves.
11/5/2009 8:20:58 PM •
Celestron...
Answered
on Nov 05, 2009
