20 Most Recent
Memorex MVD2027 DVD Player Questions & Answers
How do you clear a
According to the manual, you can't. If you forget your password, contact customer service at the
number listed in the Warranty. (in other words, Memorex offers no user help at all)
The only thing you can do here is to take the player to a workshop if it is no longer under warranty, and have them look at it. This is up to you; but ask them anyway for a quote and a second opinion before going ahead (if you wish to do so). Hopefully it won't cost a lot.
Only a workshop with the right facilities and equipment can do this. It helps if the user doesn't set parental control in the first place. Locking a player is pointless.
I downloaded a movie on my computer and burned it
The MVD2027 has a bit of a reputation for being really picky about which discs it will play. It's often especially poor with recordable DVD's, and especially with rewritable discs. This kind of behaviour can also be an early sign of a failing laser head assembly.
All you can do is to try the movie recorded onto different brands of recordable dvd and also see whether it makes any difference using DVD+R or DVD-R. Other than that, there's nothing else you can do.
DVD tray will not open
I had the same problem. I opened up the unit and gently released the tray from inside. It has been working fine since - except for the problem I just posted i.e. the remote does not work.
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
