20 Most Recent
Kenwood VR-405 Receiver Questions & Answers
How to reset?
It went out through excessive or kicked off at peak power
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Vr-405 no sound - looking for service manual
Try cleaning cleaning all the switches/connections you can. The fact that it sometimes works indicates that the components are good but that you have an intermittent connection somewhere such as a bad solder joint
Problem for Kenwood VR-405. Subwoofer has no sound
How I fixed this was to get a can of electrical contact cleaner. Any auto parts store or electronics store will carry it. Take the cover off and remove the volume knob. It's responsible for the output volume to the sub. Pry the four silver tabs open and pull apart the knob. You should see some corrosion on the contacts. Use a fingernail file to clean them off now clean it with the contact cleaner. Put it back together and you are ready to go.
