20 Most Recent
ASUS (X83Vb-X2) PC Notebook Questions & Answers
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
My Asus X83V will not boot to any CD/DVD, HDD/SSD, and/or USB/Removable Device/drive.
When you power the laptop on pay close attention to the screen to see which key you hit to get into the Bios or System Setup. Hit it and go change the boot sequence to read the CD drive first. Or you can hit the key that says Change Boot Order when you initially turn the computer on and select the CD Drive.If you can get it to read the CD drive then you can try the Check Disk Utility.]To run the check disk utility you will need a repair disc or
a operating system disc. Put the disc in the cd drive and boot from
it. You want to get to the Dos Command Prompt (Black screen with white
letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the
percentages going from high to low, this is normal. Let it run to
completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.
Try doing a Repair Install that way you don't loose your data, documents,
music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when
the options appear.
In Vista and Windows 7 you want to get to the recovery
console and look down at the bottom of the window for the Dos Command.
If you can't get it to read any drive then you might have to do a System Recovery back to factory settings.
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
