20 Most Recent Yamaha P-155 Electronic Piano Questions & Answers
When I hold in C and then press Csharp in the same octave,the C-sharp goes silent.It goes the other way around as well.They work when I tap them separately.And that problem occurs in every octave of t
It sounds like the piano is in mono setting. One note at a time can be played. Find out how to set it at poly mode, allowing multiple notes to be played at the same time.
1/28/2016 8:02:32 PM • Yamaha P-155... • Answered on Jan 28, 2016
Wood finish replacement part
If you call 714-522-9000, you can ask them for this part on order or for a distrubator in your area.
3/10/2015 5:40:28 PM • Yamaha P-155... • Answered on Mar 10, 2015
0answers
How do I reset factory settings on Yamaha p155
Turn off P155hold top C key down (furthest white key on your right)while holding this key down, turn on power,keep holding key down for 3 seconds, then let go.should default to grand piano 1 setting
11/16/2012 6:20:56 PM • Yamaha P-155... • Answered on Nov 16, 2012
0answers
Yamaha P155 wont power up,
Double check the supply... it should be a PA301 which is 16 volt DC at 3.5 amps... fairly hefty one.
Download these schematics:
http://elektrotanya.com/yamaha_psr-1500_3000_sm.pdf/download.html
and
http://elektrotanya.com/yamaha_p-120_s.pdf/download.html
A lot of Yamaha have similar circuits between different models.
When you go to these links, scroll down the page looking for a small link "Get Manual". They will only let you download two a day without registering.
The first of these has the power entry on page 154... the second is on page 60. Both use the 16 volt power adapter. See if one of these schematics is not close enough to your unit to troubleshoot it.
3/27/2011 5:08:22 AM • Yamaha P-155... • Answered on Mar 27, 2011
2answers
My Yamaha YPT-240 will not turn on. I messed around with the wire for a bit and it turned on for about 3 seconds - is it permanently broke or can I get a new lead?
You should get a new power adapter. Search for the YPT-240 Power adapter. You'll need the equivalent of the Yamaha PA130 DC 12V 1.0 A adapter. The original (<$20) and third-party power adapters are available from Amazon. First, I'd check if the YPT-240 will stay on with 6 AA batteries. That will rule out any internal problems before you order a replacement power adapter. I hope this helps. Cindy Wells
3/14/2024 10:27:09 AM • Yamaha Music • Answered on Mar 14, 2024
Will a midi interface allow me to play downloaded music on a yamaha clainova 305
Yes, with some preparation. The music will have to be in a standard MIDI file format or a format that results in standard MIDI over USB output when "played" by computer software or an external sequencer. Within the software you will probably need to create a new "instrument" if there is not already a template for the CVP 305, otherwise the tracks and sub channels in the MIDI file will be patched to GM, probably not what you want to hear.
2/17/2024 11:28:18 AM • Yamaha Music • Answered on Feb 17, 2024
2answers
What is the best way to reprogram a Yamaha WX5 Ewi
Reprogramming a Yamaha WX5 Electronic Wind Instrument (EWI) typically involves adjusting settings, assigning functions to different keys, or customizing parameters to suit your preferences. Here's a general guide on how you might reprogram a Yamaha WX5:
  1. Access the Menu:
    • Turn on your Yamaha WX5.
    • Navigate through the menu options using the buttons or controls on the instrument. Refer to your WX5's user manual for specific instructions on accessing the menu.
  2. Select Parameter to Edit:
    • Once in the menu, find the parameter you want to edit. This could include things like breath sensitivity, pitch bend range, or assigned MIDI channels.
  3. Adjust Parameters:
    • Use the controls provided on the WX5 to adjust the parameters. This might involve turning knobs, pressing buttons, or using a combination of controls.
  4. Save Changes:
    • After making your adjustments, make sure to save your changes. The WX5 typically has a save or store function within the menu. Confirm the changes and save them to the instrument's memory.
  5. Refer to the Manual:
    • Consult the user manual for your specific Yamaha WX5 model. The manual will provide detailed information on navigating menus, adjusting parameters, and saving changes.
  6. Connect to a Computer:
    • Some advanced customization may require connecting your WX5 to a computer using MIDI. You can use Yamaha's dedicated software, if available, to reprogram certain parameters.
  7. Use External Sound Modules:
    • If you're using external sound modules or synthesizers, some customization may need to be done on those devices as well. Refer to the manuals for your MIDI equipment to ensure compatibility and proper configuration.
  8. Explore Advanced Settings:
    • Depending on your proficiency and the complexity of your WX5 model, you might explore more advanced settings like custom MIDI mapping or adjusting sensitivity curves.
Remember to approach reprogramming with caution, especially if you are not familiar with all the settings. Make note of the default settings before making changes, so you can revert to them if needed. Always refer to the user manual specific to your Yamaha WX5 model for accurate and detailed instructions on reprogramming and customization. If you're unsure or uncomfortable with the process, consider seeking assistance from Yamaha support or experienced professionals in electronic wind instruments.
1/22/2024 6:24:18 AM • Yamaha Music • Answered on Jan 22, 2024
Yamaha PSR-333 Keyboard. What could be the problem of psr 333 Yamaha keyboard that is displaying Yamaha only?
Try re loading the software. It's all in the user manual.
1/19/2024 7:11:25 AM • Yamaha Music • Answered on Jan 19, 2024
I have a Yamaha US 1 organ. The foot pedal broke after 25 years of service at our church. I am trying to buy 4 part #15 foot pedal replacement pedal.. Can you help
My US 1 has had four broken pedals, and now has a fifth. I called Yamaha, and they DO have washers for the pedals but not until March. It is technically what they are calling a "failed instrument." So many of the parts have failed but been successfully replaced until now. The plastic in the pedals becomes old and brittle over time, then reaches a point where it just cracks off. The MDR has been rebuilt too, but is very temperamental. It doesn't allow me to copy discs any more. I'm trying to find a used one to replace it. Any ideas? [email protected]
1/5/2024 1:18:08 PM • Yamaha Music • Answered on Jan 05, 2024
3answers
Yamaha P-155 Electronic Piano Logo
Popular Tags
12 questions posted
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
reset factory settings yamaha p155
  • Music
