20 Most Recent Yamaha PSR-S700 ARRANGER WORKSTATION Keyboards/Midi Questions & Answers
Press the last note (right side) while powering your s700 ,this will reset your settings.
Yamaha PSR-S700... | Answered on Apr 12, 2018
change the whole screen the on capacitor 344 & 544 add resistor with value 2.2k, it will help your keyboard stay longer.
Yamaha PSR-S700... | Answered on Oct 17, 2014
Likely a connection to the backlight is being broken. Tap on the unoit and see if it pops back on. Illuminate screen with a flashlight and see if the characters can be seen when screen is faded. If they can, then the backlight is the problem... IF NOT then the display may be bad... This has been a problem and if you are under warranty, excersise it immediately... else replacement of the display is relatively expensive.
Yamaha PSR-S700... | Answered on Jul 07, 2012
Well first start by calling or emailing the manufacturer. They'll let you know who distributes their parts or If it's still available or not. But also could be a power supply problem.
Yamaha PSR-S700... | Answered on Oct 02, 2011
It sounds like one of the OTS buttons is getting triggered accidentally. There may be a build up of residue behind the button. With the unit off, try rapidly pressing the OTS buttons, one at a time. This should help to move any debris which may be creating a false contact.
If you are feeling brave, you can try opening the keyboard and getting inside, under the button with some electrical contact cleaner such as DeOxit or Servisol.But be warned: it can be difficult to get the parts back together properly! So if you don't have much servicing experience, call your local music shop to find a service technician.
Yamaha PSR-S700... | Answered on Sep 28, 2011
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Yamaha PSR-S700... | Answered on Apr 02, 2011
Do the lights come on?
Have you tried the headphone output as well as the line output(s)?
Is the volume turned up?
Do you have it plugged in with the original Yamaha AC adaptor?
https://usa.yamaha.com/support/manuals/index.html?l=en&c=keyboards&k=DGX505
Owners manual in the link.
Yamaha Music | Answered on Nov 04, 2019
seems to be a standard acoustic setup to me. If it doesn't have all the string pins in it, you'll need to get some. you simply pull out the pin, put the string in, then wind it up on the machine heads (tuners) On this one you may need to put the strings through from the inside, I'm not sure about this particular model. I like a double wrap to start on the bass strings, but that's a choice I make. You could go with nylon strings, get ball end, they're easier to use than plain. It takes a bit of know how to do plain, thy have to be wrapped just right on the pins.
Yamaha Music | Answered on Nov 02, 2019
You may find one if you google it.
Yamaha Music | Answered on Oct 27, 2019
Hi
If you are talking about cleaning the rubber contacts I wouldn't bother. Once they start to fail then it is best to replace them. You can do this either for the octave giving problems or best to replace complete set. Main part is VY84670R your piano has 6 octaves of these. with a shorter part at either end.
Yamaha Music | Answered on Oct 24, 2019
Yes you may use it as stand alone piano. Usually everytime you will power ON any yamaha psr model piano will appear as default voice.
Yamaha Music | Answered on Oct 19, 2019
try www.amazon.com,
Yamaha Music | Answered on Oct 06, 2019
This should help you trace the wires
Yamaha Music | Answered on Sep 27, 2019
Yamaha PSR-S700 ARRANGER WORKSTATION Keyboards/Midi Logo
19 questions posted
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
yamaha psr s700 keyboard whenever play
  • Music
