20 Most Recent
Line 6 Flextone III Plus Guitar Amplifier Questions & Answers
Flextone 3 one speaker not working
Then you either have a blown amp or speaker. Turn the amp off and move the wires from the speaker on the working side to the other speaker. If the other speaker works, you have a dead amp channel. if it does not, move the wires from the speaker on the non-working side to the other speaker. If that works, you have a dead speaker. Dead amp channel means take it to the shop. Dead speaker means buy a new one from Line 6 and install.
Speaker not working
try switching the leads on each speaker. if sound transfers then you have a bad channel. if you get no sound, then your speaker is bad.
The parameters shift up and down while playing
if you're using a pedal. the cat 6 wire that connects the pedal to the amp. can be coming out of the "phone jacks" that line 6 uses, all it takes is for that wire to stretch and if one line breaks . it changes the protocol. sounds like yours is intermittent. put new connectors on each end (after checking continuity),
The entire control board on
There is probably a power supply failure or with the power on reset circuit. Likely low voltage to the logic electronics. This is NOT DIY unless you are familiar with electronics.
Line 6 Low Down 400 bass guitar head
Make sure the volume and master volume are turned up. Try the amp with a different cabinet and a known good speaker cable. If you get sound, it's your speakers or your speaker cable.
If still no sound, you need your amp serviced.
10/20/2018 1:02:56 AM •
Line 6 Music
Answered
on Oct 20, 2018
