20 Most Recent Mackie ProFX12 Professional Compact Mixer Questions & Answers
It sounds like a part is burning out. If you can look inside , look for a part turning brown or getting really hot in that area. That would be the easiest thing to do if you can get in there.
Mackie ProFX12... | Answered on Apr 14, 2015
Be sure the capacitor was replaced with the correct polarity?
in the beginning of my tech career I have replaced caps back words on accident. ..
Mackie ProFX12... | Answered on Mar 08, 2015
Maybe an open ground somewhere or something needs shielded.
Mackie ProFX12... | Answered on Nov 18, 2014
Use balanced lines for the audio interconnects. Use XLR low noise mic cables or TRS type cables. IMPORTANT: Power the speakers and the mixer from the SAME receptacle, even if it means running extension cords. Ground bounce in building wiring can destroy the circuits in the equipment.
Mackie ProFX12... | Answered on Jul 11, 2011
it should be if you hook something up to an input channel like w the band i was in i had to hook my turntables up to a microphone jack on an open channel . so yeah if u plug lets say a cd player plug the output of that into the input of the mackie and make sure you have your speakers in the output of mackie all set up and it should work no problem. We have the same mackie
Mackie ProFX12... | Answered on May 28, 2011
you can take it to your local shop that you bought it from or contact Mackie and they might be able to do something for you
Mackie ProFX12... | Answered on May 09, 2011
This is probably pilot error. There are a bunch of things to do to setup this correctely. I would recommend looking at the videos about mixer setup on YouTube. There is a procedure you go through that is COMMON to most brands of the mixer. The fact that the volume meters aren't working at all implies a problem that the mixing buss is not receiving audio. Turn trim gains up, turn the faders both the channel and the main up, and UNMUTE the channels of interest and you should be getting audio through the unit. ALso does your headphone jack work?
Mackie ProFX12... | Answered on Feb 12, 2011
You probably have issues with caps in the power supply....I would check that first...open it up and look for buldging caps and replace any that you find....
Mackie Music | Answered on Sep 27, 2019
Here you go
http://www.mackie.com/products/onyx4bus/pdf/Onyx_4Bus_OM.pdf
This link to the manual is on the Mackie website
Mackie Onyx 32 4
Mackie Music | Answered on Jun 08, 2019
Hello, check if your Mackie, is with the latest Firmware update, you can get it on Mackie's official website
I sent you the Mackie technical support link
I hope you solve your concern
Greetings Franco Dosil
Hola, revisa si tu Mackie, esta con la ultima actualizacion de Firmware, puedes obtenerla en la pagina oficial de Mackie
Te envio el link del soporte tecnico de Mackie
Espero logres resolver tu inquietud
Saludos Franco Dosil
https://mackie.com/blog/support
Mackie Music | Answered on May 03, 2019
Hello Abel, I sent you the link to download the service manual of the Mackie PROFX16
I hope you can solve the problem you have with your Mackie
Hola Abel, te envio el link para que descargues el manual de servicio de la Mackie PROFX16
Espero que puedas resolver el problema que tengas con tu Mackie
https://elektrotanya.com/mackie_profx16_profx22_sch.rar/download.html
Mackie ProFX12 Professional Compact Mixer Logo
16 questions posted
Top Mackie Music Experts
Michial Gueffroy
 Grubhead
Grubhead
Joaquim Martins
Are you a Mackie Music Expert? Answer questions, earn points and help others
View Most Popular
Mackie Music
  • Mackie Music
Most Popular Question
hook mackie fx12 protools 11 thru usb
  • Music
