20 Most Recent
Kenwood KDC-322 CD Player Questions & Answers
Just took kdcmp336ax out of
Hi, protect indicates the system is seeing a short in the speakers. Is it possible there is a wiring error? Try disconnecting the speakers to see if it will go to normal operation. If you have an ohmmeter, check the impedance on each set of speaker wires. Stock speakers are usually 6 ohms or higher. If you need a wiring diagram for the car, please specify model and year. Please let me know if you have any questions, and thanks for using FixYa.
Unlock code
You will need to get serial no, model no and contact
manufacturer, they may ask for proof of ownership or receipt
Is there a code for the kdc 322 kenwood
There is no general code, thieves would have a hayday if there was one, serial no, model no and contact manufacturer, they may ask for proff of ownership or receipt
Yellow, red, and blue wires. Where does each go?
yellow wire is memory wire goes to 12 v source that is always on red wire is the ingtion wire so when u turn on key its turns on that goes to a ingtion source the blue wire is ethier amp or ant wire
I bought this radio from a friend and its asking
Tell friend to take it to the store where it was purchased, they have all the codes for equipment sold. If not an aftermarket unit, code is usually in the owners manual or hidden somewhere around the glove box.
